Open source ARM Debugger
By tatery
#191493
I'd like to program SAM4E8C but so far with no success. I use raspberry pi3 as SWD as described here: https://learn.adafruit.com/programming- ... i/overview and all is fine till command: sudo openocd
sudo openocd
Open On-Chip Debugger 0.10.0-dev-00371-g81631e4 (2016-08-29-12:46)
Licensed under GNU GPL v2
For bug reports, read
BCM2835 GPIO nums: swclk = 25, swdio = 24
BCM2835 GPIO config: srst = 18
srst_only separate srst_gates_jtag srst_push_pull connect_deassert_srst
adapter speed: 100 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
srst_only separate srst_nogate srst_push_pull connect_deassert_srst
adapter_nsrst_assert_width: 100
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : SWD only mode enabled (specify tck, tms, tdi and tdo gpios to add JTAG mode)
Info : clock speed 100 kHz
in procedure 'init' called at file "openocd.cfg", line 14
in procedure 'ocd_bouncer'
openocd output debug log (sudo openocd):
Debug: 17 16 options.c:96 add_default_dirs(): bindir=/usr/local/bin
Debug: 18 16 options.c:97 add_default_dirs(): pkgdatadir=/usr/local/share/openocd
Debug: 19 16 options.c:98 add_default_dirs(): run_prefix=
Debug: 20 16 configuration.c:42 add_script_search_dir(): adding /root/.openocd
Debug: 21 16 configuration.c:42 add_script_search_dir(): adding /usr/local/share/openocd/site
Debug: 22 16 configuration.c:42 add_script_search_dir(): adding /usr/local/share/openocd/scripts
Debug: 23 16 configuration.c:82 find_file(): found openocd.cfg
Debug: 24 17 configuration.c:82 find_file(): found /usr/local/share/openocd/scripts/interface/raspberrypi2-native.cfg
Debug: 25 17 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_interface bcm2835gpio
Debug: 26 17 command.c:143 script_debug(): command - interface ocd_interface bcm2835gpio
Debug: 28 17 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_jtag_nums'...
Debug: 29 17 command.c:323 command_new(): BUG: command 'bcm2835gpio_tck_num' does not have the '.usage' field filled out
Debug: 30 17 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_tck_num'...
Debug: 31 17 command.c:323 command_new(): BUG: command 'bcm2835gpio_tms_num' does not have the '.usage' field filled out
Debug: 32 17 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_tms_num'...
Debug: 33 17 command.c:323 command_new(): BUG: command 'bcm2835gpio_tdo_num' does not have the '.usage' field filled out
Debug: 34 17 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_tdo_num'...
Debug: 35 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_tdi_num' does not have the '.usage' field filled out
Debug: 36 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_tdi_num'...
Debug: 37 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_swd_nums'...
Debug: 38 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_swclk_num' does not have the '.usage' field filled out
Debug: 39 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_swclk_num'...
Debug: 40 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_swdio_num' does not have the '.usage' field filled out
Debug: 41 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_swdio_num'...
Debug: 42 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_srst_num' does not have the '.usage' field filled out
Debug: 43 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_srst_num'...
Debug: 44 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_trst_num' does not have the '.usage' field filled out
Debug: 45 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_trst_num'...
Debug: 46 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_speed_coeffs' does not have the '.usage' field filled out
Debug: 47 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_speed_coeffs'...
Debug: 48 18 command.c:323 command_new(): BUG: command 'bcm2835gpio_peripheral_base' does not have the '.usage' field filled out
Debug: 49 18 command.c:364 register_command_handler(): registering 'ocd_bcm2835gpio_peripheral_base'...
Debug: 50 18 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_bcm2835gpio_peripheral_base 0x3F000000
Debug: 51 19 command.c:143 script_debug(): command - bcm2835gpio_peripheral_base ocd_bcm2835gpio_peripheral_base 0x3F000000
Debug: 53 19 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_bcm2835gpio_speed_coeffs 146203 36
Debug: 54 19 command.c:143 script_debug(): command - bcm2835gpio_speed_coeffs ocd_bcm2835gpio_speed_coeffs 146203 36
Debug: 56 19 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_bcm2835gpio_swd_nums 25 24
Debug: 57 19 command.c:143 script_debug(): command - bcm2835gpio_swd_nums ocd_bcm2835gpio_swd_nums 25 24
User : 59 19 command.c:544 command_print(): BCM2835 GPIO nums: swclk = 25, swdio = 24
Debug: 60 19 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_bcm2835gpio_srst_num 18
Debug: 61 20 command.c:143 script_debug(): command - bcm2835gpio_srst_num ocd_bcm2835gpio_srst_num 18
User : 63 20 command.c:544 command_print(): BCM2835 GPIO config: srst = 18
Debug: 64 20 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_reset_config srst_only srst_push_pull
Debug: 65 20 command.c:143 script_debug(): command - reset_config ocd_reset_config srst_only srst_push_pull
User : 67 20 command.c:544 command_print(): srst_only separate srst_gates_jtag srst_push_pull connect_deassert_srst
Debug: 68 20 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select swd
Debug: 69 20 command.c:143 script_debug(): command - ocd_transport ocd_transport select swd
Debug: 70 20 command.c:323 command_new(): BUG: command 'swd' does not have the '.usage' field filled out
Debug: 71 20 command.c:364 register_command_handler(): registering 'ocd_swd'...
Debug: 72 20 bitbang.c:353 bitbang_swd_init(): bitbang_swd_init
Debug: 73 20 configuration.c:82 find_file(): found /usr/local/share/openocd/scripts/target/at91sam4XXX.cfg
Debug: 74 21 configuration.c:82 find_file(): found /usr/local/share/openocd/scripts/target/swj-dp.tcl
Debug: 75 21 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select
Debug: 76 21 command.c:143 script_debug(): command - ocd_transport ocd_transport select
Debug: 77 22 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select
Debug: 78 22 command.c:143 script_debug(): command - ocd_transport ocd_transport select
Debug: 79 22 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select
Debug: 80 22 command.c:143 script_debug(): command - ocd_transport ocd_transport select
Debug: 81 22 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select
Debug: 82 22 command.c:143 script_debug(): command - ocd_transport ocd_transport select
Debug: 83 23 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_swd newdap ATSAM4E8C cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x4ba00477
Debug: 84 23 command.c:143 script_debug(): command - ocd_swd ocd_swd newdap ATSAM4E8C cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x4ba00477
Debug: 85 23 tcl.c:549 jim_newtap_cmd(): Creating New Tap, Chip: ATSAM4E8C, Tap: cpu, Dotted: ATSAM4E8C.cpu, 8 params
Debug: 86 23 core.c:1304 jtag_tap_init(): Created Tap: ATSAM4E8C.cpu @ abs position 0, irlen 0, capture: 0x0 mask: 0x0
Debug: 87 23 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_target create ATSAM4E8C.cpu cortex_m -endian little -chain-position ATSAM4E8C.cpu
Debug: 88 23 command.c:143 script_debug(): command - ocd_target ocd_target create ATSAM4E8C.cpu cortex_m -endian little -chain-position ATSAM4E8C.cpu
Debug: 89 24 target.c:1892 target_free_all_working_areas_restore(): freeing all working areas
Debug: 90 24 command.c:364 register_command_handler(): registering 'ocd_arm'...
Debug: 91 24 command.c:364 register_command_handler(): registering 'ocd_arm'...
Debug: 92 24 command.c:364 register_command_handler(): registering 'ocd_arm'...
Debug: 93 24 command.c:364 register_command_handler(): registering 'ocd_arm'...
Debug: 94 24 command.c:364 register_command_handler(): registering 'ocd_arm'...
Debug: 95 24 command.c:364 register_command_handler(): registering 'ocd_arm'...
Debug: 96 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 97 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 98 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 99 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 100 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 101 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 102 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 103 24 command.c:364 register_command_handler(): registering 'ocd_dap'...
Debug: 104 25 command.c:364 register_command_handler(): registering 'ocd_tpiu'...
Debug: 105 25 command.c:364 register_command_handler(): registering 'ocd_itm'...
Debug: 106 25 command.c:364 register_command_handler(): registering 'ocd_itm'...
Debug: 107 25 command.c:364 register_command_handler(): registering 'ocd_cortex_m'...
Debug: 108 25 command.c:364 register_command_handler(): registering 'ocd_cortex_m'...
Debug: 109 25 command.c:364 register_command_handler(): registering 'ocd_cortex_m'...
Debug: 110 25 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 111 25 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 112 25 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 113 25 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 114 25 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 115 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 116 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 117 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 118 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 119 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 120 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 121 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 122 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 123 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 124 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 125 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 126 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 127 26 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 128 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 129 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 130 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 131 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 132 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 133 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 134 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 135 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 136 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 137 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 138 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 139 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 140 27 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 141 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 142 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 143 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 144 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 145 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 146 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 147 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 148 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 149 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 150 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 151 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 152 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 153 28 command.c:364 register_command_handler(): registering 'ocd_ATSAM4E8C.cpu'...
Debug: 154 29 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_ATSAM4E8C.cpu configure -work-area-phys 0x20000000 -work-area-size 0x4000 -work-area-backup 0
Debug: 155 29 command.c:143 script_debug(): command - ocd_ATSAM4E8C.cpu ocd_ATSAM4E8C.cpu configure -work-area-phys 0x20000000 -work-area-size 0x4000 -work-area-backup 0
Debug: 156 29 target.c:1892 target_free_all_working_areas_restore(): freeing all working areas
Debug: 157 29 target.c:1892 target_free_all_working_areas_restore(): freeing all working areas
Debug: 158 29 target.c:1892 target_free_all_working_areas_restore(): freeing all working areas
Debug: 159 29 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_adapter_khz 100
Debug: 160 29 command.c:143 script_debug(): command - adapter_khz ocd_adapter_khz 100
Debug: 162 29 core.c:1631 jtag_config_khz(): handle jtag khz
Debug: 163 29 core.c:1598 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 164 29 core.c:1598 adapter_khz_to_speed(): convert khz to interface specific speed value
User : 165 29 command.c:544 command_print(): adapter speed: 100 kHz
Debug: 166 30 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_adapter_nsrst_delay 100
Debug: 167 30 command.c:143 script_debug(): command - adapter_nsrst_delay ocd_adapter_nsrst_delay 100
User : 169 30 command.c:544 command_print(): adapter_nsrst_delay: 100
Debug: 170 30 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select
Debug: 171 30 command.c:143 script_debug(): command - ocd_transport ocd_transport select
Debug: 172 30 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport select
Debug: 173 30 command.c:143 script_debug(): command - ocd_transport ocd_transport select
Debug: 174 30 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_cortex_m reset_config sysresetreq
Debug: 175 30 command.c:143 script_debug(): command - ocd_cortex_m ocd_cortex_m reset_config sysresetreq
User : 177 31 command.c:544 command_print(): cortex_m reset_config sysresetreq
Debug: 178 31 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_reset_config srst_nogate
Debug: 179 31 command.c:143 script_debug(): command - reset_config ocd_reset_config srst_nogate
User : 181 31 command.c:544 command_print(): srst_only separate srst_nogate srst_push_pull connect_deassert_srst
Debug: 182 31 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_adapter_nsrst_delay 100
Debug: 183 31 command.c:143 script_debug(): command - adapter_nsrst_delay ocd_adapter_nsrst_delay 100
User : 185 31 command.c:544 command_print(): adapter_nsrst_delay: 100
Debug: 186 31 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_adapter_nsrst_assert_width 100
Debug: 187 31 command.c:143 script_debug(): command - adapter_nsrst_assert_width ocd_adapter_nsrst_assert_width 100
User : 189 31 command.c:544 command_print(): adapter_nsrst_assert_width: 100
Debug: 190 32 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 191 32 command.c:143 script_debug(): command - init ocd_init
Debug: 193 32 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_target init
Debug: 194 32 command.c:143 script_debug(): command - ocd_target ocd_target init
Debug: 196 32 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 197 32 command.c:143 script_debug(): command - ocd_target ocd_target names
Debug: 198 32 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_ATSAM4E8C.cpu cget -event gdb-flash-erase-start
Debug: 199 33 command.c:143 script_debug(): command - ocd_ATSAM4E8C.cpu ocd_ATSAM4E8C.cpu cget -event gdb-flash-erase-start
Debug: 200 33 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_ATSAM4E8C.cpu configure -event gdb-flash-erase-start reset init
Debug: 201 33 command.c:143 script_debug(): command - ocd_ATSAM4E8C.cpu ocd_ATSAM4E8C.cpu configure -event gdb-flash-erase-start reset init
Debug: 202 33 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_ATSAM4E8C.cpu cget -event gdb-flash-write-end
Debug: 203 33 command.c:143 script_debug(): command - ocd_ATSAM4E8C.cpu ocd_ATSAM4E8C.cpu cget -event gdb-flash-write-end
Debug: 204 33 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_ATSAM4E8C.cpu configure -event gdb-flash-write-end reset halt
Debug: 205 33 command.c:143 script_debug(): command - ocd_ATSAM4E8C.cpu ocd_ATSAM4E8C.cpu configure -event gdb-flash-write-end reset halt
Debug: 206 34 target.c:1317 handle_target_init_command(): Initializing targets...
Debug: 207 34 command.c:364 register_command_handler(): registering 'ocd_target_request'...
Debug: 208 34 command.c:364 register_command_handler(): registering 'ocd_trace'...
Debug: 209 34 command.c:364 register_command_handler(): registering 'ocd_trace'...
Debug: 210 34 command.c:364 register_command_handler(): registering 'ocd_fast_load_image'...
Debug: 211 34 command.c:364 register_command_handler(): registering 'ocd_fast_load'...
Debug: 212 34 command.c:364 register_command_handler(): registering 'ocd_profile'...
Debug: 213 34 command.c:364 register_command_handler(): registering 'ocd_virt2phys'...
Debug: 214 34 command.c:364 register_command_handler(): registering 'ocd_reg'...
Debug: 215 34 command.c:364 register_command_handler(): registering 'ocd_poll'...
Debug: 216 34 command.c:364 register_command_handler(): registering 'ocd_wait_halt'...
Debug: 217 34 command.c:364 register_command_handler(): registering 'ocd_halt'...
Debug: 218 34 command.c:364 register_command_handler(): registering 'ocd_resume'...
Debug: 219 35 command.c:364 register_command_handler(): registering 'ocd_reset'...
Debug: 220 35 command.c:364 register_command_handler(): registering 'ocd_soft_reset_halt'...
Debug: 221 35 command.c:364 register_command_handler(): registering 'ocd_step'...
Debug: 222 35 command.c:364 register_command_handler(): registering 'ocd_mdw'...
Debug: 223 35 command.c:364 register_command_handler(): registering 'ocd_mdh'...
Debug: 224 35 command.c:364 register_command_handler(): registering 'ocd_mdb'...
Debug: 225 35 command.c:364 register_command_handler(): registering 'ocd_mww'...
Debug: 226 35 command.c:364 register_command_handler(): registering 'ocd_mwh'...
Debug: 227 35 command.c:364 register_command_handler(): registering 'ocd_mwb'...
Debug: 228 35 command.c:364 register_command_handler(): registering 'ocd_bp'...
Debug: 229 35 command.c:364 register_command_handler(): registering 'ocd_rbp'...
Debug: 230 35 command.c:364 register_command_handler(): registering 'ocd_wp'...
Debug: 231 36 command.c:364 register_command_handler(): registering 'ocd_rwp'...
Debug: 232 36 command.c:364 register_command_handler(): registering 'ocd_load_image'...
Debug: 233 36 command.c:364 register_command_handler(): registering 'ocd_dump_image'...
Debug: 234 36 command.c:364 register_command_handler(): registering 'ocd_verify_image'...
Debug: 235 36 command.c:364 register_command_handler(): registering 'ocd_test_image'...
Debug: 236 36 command.c:364 register_command_handler(): registering 'ocd_reset_nag'...
Debug: 237 36 command.c:364 register_command_handler(): registering 'ocd_ps'...
Debug: 238 36 command.c:364 register_command_handler(): registering 'ocd_test_mem_access'...
Info : 239 36 bcm2835gpio.c:428 bcm2835gpio_init(): BCM2835 GPIO JTAG/SWD bitbang driver
Info : 240 36 bcm2835gpio.c:440 bcm2835gpio_init(): SWD only mode enabled (specify tck, tms, tdi and tdo gpios to add JTAG mode)
Debug: 241 36 bcm2835gpio.c:507 bcm2835gpio_init(): saved pinmux settings: tck 0 tms 0 tdi 0 tdo 0 trst 0 srst 0
Debug: 242 36 bitbang.c:408 bitbang_switch_to_swd(): bitbang_switch_to_swd
Debug: 243 36 bitbang.c:360 bitbang_exchange(): bitbang_exchange
Debug: 244 37 core.c:1598 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 245 37 core.c:1601 adapter_khz_to_speed(): have interface set up
Debug: 246 37 core.c:1598 adapter_khz_to_speed(): convert khz to interface specific speed value
Debug: 247 37 core.c:1601 adapter_khz_to_speed(): have interface set up
Info : 248 37 core.c:1386 adapter_init(): clock speed 100 kHz
Debug: 249 37 openocd.c:135 handle_init_command(): Debug Adapter init complete
Debug: 250 37 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_transport init
Debug: 251 37 command.c:143 script_debug(): command - ocd_transport ocd_transport init
Debug: 253 37 transport.c:239 handle_transport_init(): handle_transport_init
Debug: 254 37 bitbang.c:383 bitbang_swd_switch_seq(): bitbang_swd_switch_seq
Debug: 255 37 bitbang.c:391 bitbang_swd_switch_seq(): JTAG-to-SWD
Debug: 256 37 bitbang.c:360 bitbang_exchange(): bitbang_exchange
Debug: 257 38 bitbang.c:420 bitbang_swd_read_reg(): bitbang_swd_read_reg
Debug: 258 38 bitbang.c:360 bitbang_exchange(): bitbang_exchange
Debug: 259 38 bitbang.c:360 bitbang_exchange(): bitbang_exchange
Debug: 260 39 bitbang.c:447 bitbang_swd_read_reg(): JUNK DP read reg 0 = ffffffff
Debug: 261 39 bitbang.c:470 bitbang_swd_read_reg(): No valid acknowledge: ack=7
Debug: 262 39 bitbang.c:479 bitbang_swd_write_reg(): bitbang_swd_write_reg
Debug: 263 39 bitbang.c:483 bitbang_swd_write_reg(): Skip bitbang_swd_write_reg because queued_retval=7
Debug: 264 39 bitbang.c:531 bitbang_swd_run_queue(): bitbang_swd_run_queue
Debug: 265 39 bitbang.c:360 bitbang_exchange(): bitbang_exchange
Debug: 266 39 bitbang.c:538 bitbang_swd_run_queue(): SWD queue return value: 07
Debug: 267 39 command.c:626 run_command(): Command failed with error code 7
User : 268 40 command.c:687 command_run_line(): in procedure 'init' called at file "openocd.cfg", line 14
Debug: 269 40 command.c:626 run_command(): Command failed with error code -4
User : 270 40 command.c:687 command_run_line():
Debug: 271 40 command.c:143 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 272 40 command.c:143 script_debug(): command - init ocd_init
My configuration file openocd.cfg content:
source [find interface/raspberrypi2-native.cfg]
set CHIPNAME ATSAM4E8C
source [find target/at91sam4XXX.cfg]
# did not yet manage to make a working setup using srst
#reset_config srst_only
init
targets
reset halt
I've also tried with
set CHIPNAME AT91SAM4E8C
Did anyone experience similar issue with SAM4E8C and have some solution?
I've already checked signals with an oscilloscope and all seems to be correct. I suppose this is some issue with openocd configuration for SAM4E8C. Could you please share your configuration?
By tatery
#191784
Finally I've managed it to work. There were a problems with reset configuration, SWD/JTAG frequency and voltage level converter (RPi works on 3V3, target MCU with 1V8).
My working configuration:
rpi_swd.cfg
openocd.cfg
source [find rpi_swd.cfg]
set _FLASHNAME $_CHIPNAME.flash
flash bank $_FLASHNAME at91sam4 0x00400000 0 1 1 $_TARGETNAME info
adapter_khz 250
init
targets
reset halt
program test.hex verify reset
RPi pinout for SWD:
GPIO25 (PIN22) --> SWCLK
GPIO24 (PIN18) --> SWDIO
GPIO18 (PIN12) --> SRST
Voltage level converter: TXB0104
Nice tutorial on how to configure RPi to be a JTAG or SWD: https://movr0.com/2016/09/02/use-raspbe ... d-adapter/
