- Mon Sep 18, 2006 3:59 am
#19076
I just looked into a compiler warning;
it seems the test for leading digit in handle_var_command() is incorrect.
Possible fix below.
Cheers
Anders
Possible fix below.
Cheers
Anders
--- src/helper/interpreter.c (revision 98)
+++ src/helper/interpreter.c (working copy)
@@ -126,7 +126,7 @@
last_var_p = &((*last_var_p)->next);
- if ((args[0][0] >= 0) && (args[0][0] <= 9))
+ if ((args[0][0] >= '0') && (args[0][0] <= '9'))
command_print(cmd_ctx, "invalid name specified (first character may not be a number)");
return ERROR_OK;
