- Fri Sep 08, 2006 11:26 am
#18610
I am having trouble running a program in RAM on an LPC2106 by means of OPenOCD's GDB interface - but only if the Flash is blank. What seems
to happen is that
- At reset, Philips boot loader takes over.
- My debugger stops the boot loader (Control-C to GDB server). I see the
registers PC usually 7FFFE24C, CPSR has N, I, F, and SVC mode.
Now, the Philips docs say that most of the boot code is in Thumb mode,
and the code at 7FFFE24C makes a lot more sense when disassembled as
Thumb code, but CPSR as reported by OpenOCD's GDB server says
ARM.
- My debugger sets CPSR to 0xD3 (ARM mode, interrupts disabled, SVC
mode)
- My debugger sets PC to 0x40000000, where my program starts
- My debugger sets a hardware breakpoint, says GO - and never hits the
breakpoint.
- Try again, but this time use single-step (GDB server 's' command).
Program stops with PC=0x40000002. Clearly, the processor is still in
Thumb mode, even though I set CPSR.
- Third try - don't even load my program. Apply power to target,
start OpenOCD, open a TELNET session to localhost 3333
Send $p19#da - get +$d3000080#bf (CPSR as above, little-endian byte
order)
Send +$pf#d6 - get +$4ce2ff7f#97 (PC as above: 7FFE2E24C)
Send +$s#73 - get +$T05#b9 (step, signal 5)
Send +$pf#d6 - get +$4ee2ff7f#99 (PC as above: 7FFE2E24E)
Any ideas as to what is going on - or more importantly, how to fix it?
Background:
I am writing a debugger (NoICE, at www.noicedebugger.com) and trying
to use OpenOCD as a GDB server. I also have support for RDI (tested
with H-JTAG and Segger's RDI DLL), and experimentally with OpenOCD's port 4444 command interface.
All three interfaces are operational, and neither RDI nor the
OpenOCD/4444 interface exhibits this problem. Both RDI and
OpenOCD/4444 show all the ARM shadow registers, while GDB only shows
the current set.
My assumption is that somehow CPSR isn't making it to the target. If
I run OpenOCD at debug level 3, I see a flurry of activity that claims
that it is (just before the program is run, rather than when I send the
register message). I have looked through the OpenOCD code, but I don't
know enough about ARM JTAG to really understand everything that is
going on.
to happen is that
ARM.
mode)
breakpoint.
order)
Background:
the current set.
going on.
