- Tue Jan 05, 2016 9:50 am
#187083
Hello everyone,
This is my first post ever on this board and I am also fairly new to the world of JTAG debugging, I have used a few commercial products before but I would like to make the switch to OpenOCD and I am experiencing a lot of failures so far. I have tried to attach to my Beaglebone Black using a Flyswatter2 and the kit that they provide and most of my results look something like this:
$ ./openocd -f interface/ftdi/flyswatter2.cfg -f
board/ti_beaglebone_with_fs2.cfg -c init -c "reset init"
Open On-Chip Debugger 0.10.0-dev-00149-g8229d52 (2015-12-23-11:37)
Licensed under GNU GPL v2
For bug reports, read
Warn : Interface already configured, ignoring
adapter speed: 16000 kHz
Info : auto-selecting first available session transport "jtag". To
override use 'transport select <transport>'.
Warn : target name is deprecated use: 'cortex_a'
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
connect_deassert_srst
Info : clock speed 16000 kHz
Info : JTAG tap: am335x.jrc tap/device found: 0x2b94402f (mfg: 0x017,
part: 0xb944, ver: 0x2)
Info : JTAG tap: am335x.dap enabled
Warn : Timeout (1000ms) waiting for ACK=OK/FAULT in JTAG-DP transaction
- aborting
Error: JTAG-DP OVERRUN - check clock, memaccess, or reduce jtag speed
Error: MEM_AP_CSW 0x2800060, MEM_AP_TAR 0x0
Error: Target not examined yet
in procedure 'reset'
in procedure 'ocd_bouncer'
I have tried to reduce the adapter speed with some success, where the device actually reboots but all hell breaks loose once the kernel starts at which point I get error messages similar to the ones above.
I am not really sure where to start as those error messages are still a little obscure to me, would anyone have any ideas/thoughts/suggestions? I'd be willing to dig in the source and make some adjustments if need be, but right now I'm a little bit too clueless to do so!
Thanks in advance.
Francois
- aborting
Thanks in advance.
Francois
