Open source ARM Debugger
By pgasper
#18059
I'm using:
WinARM Version 20060606
OpenOCD - Version SVN88
( Open On-Chip Debugger (2006-08-01 12:00 CEST) )
ATSAM7A3-EK eval board
The code compile successfully in both IAR and GCC. But I'm only able successfully load to flash the IAR build. I'm not entirely sure if it is a GCC issue or a flash loading issue. Both builds seem to return success. But the GCC version doesn not run. Can someone verify this from the log file?
IAR build log: (openocd_log_iar_basic_insight.txt)
Debug: jtag.c:1180 jtag_init():
Debug: parport.c:358 parport_init(): requesting privileges for parallel port 0x378...
Debug: parport.c:368 parport_init(): ...privileges granted
Debug: parport.c:203 parport_reset(): trst: 0, srst: 0
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1070 jtag_reset_callback():
Debug: openocd.c:98 main(): jtag init complete
Debug: arm7_9_common.c:651 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 0
Warning: arm7_9_common.c:675 arm7_9_assert_reset(): srst resets test logic, too
Debug: parport.c:203 parport_reset(): trst: 1, srst: 1
Debug: arm7_9_common.c:714 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 2
Debug: openocd.c:102 main(): target init complete
Debug: openocd.c:106 main(): flash init complete
Debug: gdb_server.c:1093 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:155 embeddedice_read_reg_w_check(): 1
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 3
Debug: arm7_9_common.c:777 arm7_9_halt(): target->state: running
Debug: embeddedice.c:251 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:251 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:615 arm7_9_poll(): DBGACK set, dbg_state->value: 0x19
Debug: embeddedice.c:251 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:907 arm7_9_debug_entry(): target entered debug from Thumb state
Debug: arm7_9_common.c:911 arm7_9_debug_entry(): r0_thumb: 0x0000b823, pc_thumb: 0x00000254
Debug: arm7_9_common.c:934 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug: arm7_9_common.c:945 arm7_9_debug_entry(): thumb state, applying fixups
Debug: arm7_9_common.c:975 arm7_9_debug_entry(): entered debug state at PC 0x24e
Debug: target.c:439 target_call_event_callbacks(): target event 0
Debug: arm7_9_common.c:777 arm7_9_halt(): target->state: halted
Warning: arm7_9_common.c:781 arm7_9_halt(): target was already halted
Debug: gdb_server.c:124 gdb_get_char(): received '+$Hc-1#09'
Info: server.c:67 add_connection(): accepted 'gdb' connection from 0
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'Hc-1'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$#00'
Debug: gdb_server.c:124 gdb_get_char(): received '+$qC#b4'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qC'
Debug: gdb_server.c:124 gdb_get_char(): received '+$qOffsets#4b'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qOffsets'
Debug: gdb_server.c:124 gdb_get_char(): received '+$?#3f'
Debug: gdb_server.c:989 gdb_input(): recevied packet: '?'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$S02#b5'
Debug: gdb_server.c:124 gdb_get_char(): received '+$Hg0#df'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'Hg0'
Debug: gdb_server.c:124 gdb_get_char(): received '+$pf#d6'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'pf'
Debug: gdb_server.c:567 gdb_get_register_packet():
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$4e020000#bb'
Debug: gdb_server.c:124 gdb_get_char(): received '+$m24c,4#96'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'm24c,4'
Debug: gdb_server.c:669 gdb_read_memory_packet(): addr: 0x0000024c, len: 0x00000004
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0x0000024c, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$8842fad3#34'
Debug: gdb_server.c:124 gdb_get_char(): received '+'
Debug: gdb_server.c:124 gdb_get_char(): received '$qRcmd,706f6c6c#58'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qRcmd,706f6c6c'
Debug: arm7_9_common.c:615 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O7461726765742073746174653a2068616c7465640a#76'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O7461726765742068616c74656420696e205468756d622073746174652064756520746f20646562756720726571756573742c2063757272656e74206d6f64653a2053757065727669736f720a#8f'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O637073723a20307834303030303031332070633a20307830303030303234650a#8b'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$OK#9a'
Debug: gdb_server.c:124 gdb_get_char(): received '$qRcmd,666c61736820696e666f2030#a0'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qRcmd,666c61736820696e666f2030'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O23313a206174393173616d3720617420307830303030303030302c2073697a6520307830303030303030302c20627573776964746820302c2063686970776964746820300a#58'
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffff240, size: 0x00000004, count: 0x00000001
Debug: at91sam7.c:310 at91sam7_read_part_info(): nvptyp: 0x002, arch: 0x0060, alt_id: 0x0000, alt_addr: 0x3fac08
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffffc24, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffffc30, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffffc2c, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xffffff68, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O0a#e0'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O6174393173616d3720696e666f726d6174696f6e3a0a#da'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O636964723a20307832363061303934312c20617263683a203078303036302c206570726f633a2041524d3754444d492c2076657273696f6e3a30783030312c2020666c61736873697a653a20307830303034303030300a#83'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O6d617374657220636c6f636b28657374696d61746564293a2034383136376b487a200a#4d'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O7061676573697a653a203235362c206c6f636b626974733a203136203078666666382c20706167657320696e206c6f636b20726567696f6e3a203634200a#89'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O73656375726974796269743a20302c206e766d626974733a203078300a#48'
Debug: gdb_server.c:124 gdb_get_char(): received '$qRcmd,666c617368207772697465203020453a5c42617369632e62696e20307830#50'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qRcmd,666c617368207772697465203020453a5c42617369632e62696e20307830'
Debug: at91sam7.c:638 at91sam7_write(): first_page: 0, last_page: 4, count 1024
Debug: at91sam7.c:226 at91sam7_set_flash_mode(): fmcn: 73
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0xffffff68, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00100000, size: 0x00000004, count: 0x00000040
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0xffffff64, size: 0x00000004, count: 0x00000001
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000001, pagenumber:
Debug: at91sam7.c:243 at91sam7_wait_status_busy(): status: 0xfff80001
Debug: at91sam7.c:661 at91sam7_write(): Flash command: 0xffffffff, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000101, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000201, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000301, pagenumber:
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O77726f74652066696c6520453a5c42617369632e62696e20746f20666c6173682062616e6b2030206174206f6666736574203078303030303030303020696e2030732031353632353375730a#82'
Debug: gdb_server.c:124 gdb_get_char(): received '$qRcmd,73687574646f776e#e1'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qRcmd,73687574646f776e'
GCC build log: (openocd_log_gcc_basic.txt)
Debug: arm7_9_common.c:911 arm7_9_debug_entry(): r0_thumb: 0x0001f291, pc_thumb: 0x0000024c
Debug: arm7_9_common.c:975 arm7_9_debug_entry(): entered debug state at PC 0x246
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$46020000#8c'
Debug: gdb_server.c:124 gdb_get_char(): received '+$m244,4#67'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'm244,4'
Debug: gdb_server.c:669 gdb_read_memory_packet(): addr: 0x00000244, len: 0x00000004
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0x00000244, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$00e0401c#ed'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O637073723a20307834303030303031332070633a20307830303030303234360a#89'
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O6d617374657220636c6f636b28657374696d61746564293a2034383137386b487a200a#4f'
Debug: gdb_server.c:124 gdb_get_char(): received '$qRcmd,666c617368207772697465203020453a5c6d61696e2e68657820307830#22'
Debug: gdb_server.c:989 gdb_input(): recevied packet: 'qRcmd,666c617368207772697465203020453a5c6d61696e2e68657820307830'
Debug: at91sam7.c:638 at91sam7_write(): first_page: 0, last_page: 34, count 8488
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000401, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000501, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000601, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000701, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000801, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000901, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000a01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000b01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000c01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000d01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000e01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000f01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001001, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001101, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001201, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001301, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001401, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001501, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001601, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001701, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001801, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001901, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001a01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001b01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001c01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001d01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001e01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001f01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a002001, pagenumber:
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00100000, size: 0x00000004, count: 0x0000000a
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a002101, pagenumber:
Debug: gdb_server.c:160 gdb_put_packet(): sending packet '$O77726f74652066696c6520453a5c6d61696e2e68657820746f20666c6173682062616e6b2030206174206f6666736574203078303030303030303020696e2030732038393036343275730a#5b'
By mlu
#18098
If you want to check if the flash download worked then you should read back the flash after download (and possibly a reset) and compare to the binary file.
The logs seems to indicate that both versions downloaded OK,
ond no problem with with OpenOCD, JTAG or the board.
OpenOCD does not handle binaries compiled with different build systems in different ways.
If the IAR versíon downloads and runs then the flashing probably works correctly.
If the gcc downloads but does not run then there is some other problem with the gcc compiled version. It could be linker scripts, startup code, ibraries or interrupt handling.
These things are similar but slightly different when using IAR and gcc.
Geetings
/Magnus
By pgasper
#18205
Yes, the problem was with my compile flags and linker.
Thanks.
