- Thu Aug 17, 2006 3:05 am
#17385
Hi.
I was used to have:
- Linux
- openocd rev 82
- Amontec JTAG key
- STR7 target
to work correctly
Now I try to use rev 86 and openocd does not work anymore. It says:
Info: openocd.c:82 main(): Open On-Chip Debugger (2006-08-01 12:00 CEST)
Info: configuration.c:50 configuration_output_handler(): Command ftd2xx_device_desc not found
Info: configuration.c:50 configuration_output_handler(): Command ftd2xx_layout not found
Info: configuration.c:50 configuration_output_handler(): Command ftd2xx_vid_pid not found
Error: jtag.c:1223 jtag_init(): No valid jtag interface found (ftd2xx)
Error: jtag.c:1224 jtag_init(): compiled-in jtag interfaces:
Error: jtag.c:1227 jtag_init(): 0: ft2232
It seems that the ./configure options changed recently, i.e. --enable-ftd2xx became --enable-ft2232-ftd2xx
Also openocd is now trying to look for libd2xx.so instead of libftd2xx.so
Anyone has rev 86 working on Linux with ftd2xx lib ? How should I call ./configure to use it with Amontec JTAG key?
Thanks!
Bernard
I was used to have:
- Linux
- openocd rev 82
- Amontec JTAG key
- STR7 target
to work correctly
Thanks!
Bernard
