Using catch command in JimTcl to get command return status
Posted: Mon Dec 01, 2014 4:57 am
Dear All,
I would like to know, how to get the return status of command executed in openocd.
After exploring a while, i figured out "catch" command.
But, there is inconsistency, because, there are commands, on error case, they return ERROR_OK.
for example,
COMMAND_HANDLER(handle_flash_erase_command)
retval = flash_driver_erase(p, first, last);
if ((ERROR_OK == retval) && (duration_measure(&bench) == ERROR_OK)) {
command_print(CMD_CTX, "erased sectors %" PRIu32 " "
"through %" PRIu32 " on flash bank %d "
"in %fs", first, last, p->bank_number, duration_elapsed(&bench));
return ERROR_OK; -- this should be "return retval".
Any thoughts, how to retrieve return status for commands and validate failure??
Thanks and Regards,
Harish Kumar V
for example,
Thanks and Regards,
Harish Kumar V
