- Tue Aug 29, 2006 11:19 am
#18095
Hi!
I have a problem. I am trying use the Openocd with LPC2138 (ARM7TDMI-S) and Wiggler cable in Debian GNU/Linux 2.6.16 but don't run. When I run the comand openocd -f configfile.cfg -d this error happen: Error: jtag.c:1123 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 3f.
That's all right with my cable Wiggler. I already used it with OpenWince Jtag and Spartan3 Kit. My Wiggler cable is that: http://wiki.openwrt.org/OpenWrtDocs/Cus ... JTAG_Cable .
My ARM's board haven't any pull-up neither pull-down resistor. This is necessary? I used Openocd with MCB2130 (Keil board with LPC2138) and Wiggler cable and happened the same error even so this board has pull-up resistors in TRST, TDI, TMS and TDO signals and pull-down in TCK and RTCK signals. The RTCK signal there isn't in my Wiggler cable. As the standard jtag 1149.1 the TDI, TDO, TCK and TMS signals are essential to comunication, but TRST and RTCK aren't.
The configuration in my config-file is the same used in: http://www.siwawi.arubi.uni-kl.de/avr_p ... index.html
I need only to program the flash memory...
