yes, I compiled the latest version available on your git
even without using gdb, if I use openocd to flash the memory and perform a single step instruction, I am led to a hardfault:
Code: Select allguihashimoto@invslave:~/Desktop/vldiscovery/projects/headcon$ openocd -d3 -f openocd.cfg
Open On-Chip Debugger 0.8.0-dev-00381-gf91390f (2014-03-13-17:38)
Licensed under GNU GPL v2
For bug reports, read
User : 13 2 command.c:546 command_print(): debug_level: 3
Debug: 14 2 options.c:98 add_default_dirs(): bindir=/usr/local/bin
Debug: 15 2 options.c:99 add_default_dirs(): pkgdatadir=/usr/local/share/openocd
Debug: 16 2 options.c:100 add_default_dirs(): run_prefix=
Debug: 17 2 configuration.c:44 add_script_search_dir(): adding /home/guihashimoto/.openocd
Debug: 18 3 configuration.c:44 add_script_search_dir(): adding /usr/local/share/openocd/site
Debug: 19 3 configuration.c:44 add_script_search_dir(): adding /usr/local/share/openocd/scripts
Debug: 20 3 configuration.c:84 find_file(): found openocd.cfg
Debug: 21 3 configuration.c:84 find_file(): found /usr/local/share/openocd/scripts/interface/stlink-v2.cfg
Debug: 22 3 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_interface hla
Debug: 23 3 command.c:145 script_debug(): command - interface ocd_interface hla
Debug: 25 3 command.c:366 register_command_handler(): registering 'ocd_hla_device_desc'...
Debug: 26 3 command.c:366 register_command_handler(): registering 'ocd_hla_serial'...
Debug: 27 3 command.c:366 register_command_handler(): registering 'ocd_hla_layout'...
Debug: 28 4 command.c:366 register_command_handler(): registering 'ocd_hla_vid_pid'...
Debug: 29 4 command.c:366 register_command_handler(): registering 'ocd_trace'...
Debug: 30 4 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla_layout stlink
Debug: 31 4 command.c:145 script_debug(): command - hla_layout ocd_hla_layout stlink
Debug: 33 4 hla_interface.c:176 hl_interface_handle_layout_command(): hl_interface_handle_layout_command
Debug: 34 4 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla_device_desc ST-LINK/V2
Debug: 35 4 command.c:145 script_debug(): command - hla_device_desc ocd_hla_device_desc ST-LINK/V2
Debug: 37 4 hla_interface.c:150 hl_interface_handle_device_desc_command(): hl_interface_handle_device_desc_command
Debug: 38 4 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla_vid_pid 0x0483 0x3748
Debug: 39 4 command.c:145 script_debug(): command - hla_vid_pid ocd_hla_vid_pid 0x0483 0x3748
Debug: 41 5 hla_interface.c:204 hl_interface_handle_vid_pid_command(): hl_interface_handle_vid_pid_command
Debug: 42 5 configuration.c:84 find_file(): found /usr/local/share/openocd/scripts/target/stm32f4x_stlink.cfg
Debug: 43 5 configuration.c:84 find_file(): found /usr/local/share/openocd/scripts/target/stm32_stlink.cfg
Debug: 44 5 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_transport select hla_swd
Debug: 45 5 command.c:145 script_debug(): command - ocd_transport ocd_transport select hla_swd
Debug: 46 5 hla_transport.c:187 hl_transport_select(): hl_transport_select
Debug: 47 5 command.c:366 register_command_handler(): registering 'ocd_hla'...
Debug: 48 5 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 49 5 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 50 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 51 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 52 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 53 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 54 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 55 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 56 6 command.c:366 register_command_handler(): registering 'ocd_jtag'...
Debug: 57 6 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_hla newtap stm32f4x cpu -expected-id 0x2ba01477
Debug: 58 6 command.c:145 script_debug(): command - ocd_hla ocd_hla newtap stm32f4x cpu -expected-id 0x2ba01477
Debug: 59 6 hla_tcl.c:104 jim_hl_newtap_cmd(): Creating New Tap, Chip: stm32f4x, Tap: cpu, Dotted: stm32f4x.cpu, 2 params
Debug: 60 6 hla_tcl.c:114 jim_hl_newtap_cmd(): Processing option: -expected-id
Debug: 61 6 core.c:1319 jtag_tap_init(): Created Tap: stm32f4x.cpu @ abs position 0, irlen 0, capture: 0x0 mask: 0x0
Debug: 62 6 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target create stm32f4x.cpu hla_target -chain-position stm32f4x.cpu
Debug: 63 7 command.c:145 script_debug(): command - ocd_target ocd_target create stm32f4x.cpu hla_target -chain-position stm32f4x.cpu
Debug: 64 7 target.c:1718 target_free_all_working_areas_restore(): freeing all working areas
Debug: 65 7 command.c:366 register_command_handler(): registering 'ocd_arm'...
Debug: 66 7 command.c:366 register_command_handler(): registering 'ocd_arm'...
Debug: 67 7 command.c:366 register_command_handler(): registering 'ocd_arm'...
Debug: 68 7 command.c:366 register_command_handler(): registering 'ocd_arm'...
Debug: 69 7 command.c:366 register_command_handler(): registering 'ocd_arm'...
Debug: 70 7 command.c:366 register_command_handler(): registering 'ocd_arm'...
Debug: 71 7 hla_target.c:367 adapter_target_create(): adapter_target_create
Debug: 72 7 hla_target.c:338 adapter_init_arch_info(): adapter_init_arch_info
Debug: 73 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 74 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 75 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 76 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 77 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 78 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 79 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 80 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 81 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 82 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 83 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 84 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 85 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 86 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 87 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 88 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 89 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 90 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 91 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 92 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 93 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 94 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 95 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 96 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 97 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 98 7 command.c:366 register_command_handler(): registering 'ocd_stm32f4x.cpu'...
Debug: 99 7 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu configure -work-area-phys 0x20000000 -work-area-size 0x10000 -work-area-backup 0
Debug: 100 7 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu configure -work-area-phys 0x20000000 -work-area-size 0x10000 -work-area-backup 0
Debug: 101 7 target.c:1718 target_free_all_working_areas_restore(): freeing all working areas
Debug: 102 7 target.c:1718 target_free_all_working_areas_restore(): freeing all working areas
Debug: 103 7 target.c:1718 target_free_all_working_areas_restore(): freeing all working areas
Debug: 104 7 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_flash bank stm32f4x.flash stm32f2x 0 0 0 0 stm32f4x.cpu
Debug: 105 7 command.c:145 script_debug(): command - ocd_flash ocd_flash bank stm32f4x.flash stm32f2x 0 0 0 0 stm32f4x.cpu
Debug: 107 7 command.c:366 register_command_handler(): registering 'ocd_stm32f2x'...
Debug: 108 7 command.c:366 register_command_handler(): registering 'ocd_stm32f2x'...
Debug: 109 7 command.c:366 register_command_handler(): registering 'ocd_stm32f2x'...
Debug: 110 7 tcl.c:807 handle_flash_bank_command(): 'stm32f2x' driver usage field missing
User : 111 7 command.c:691 command_run_line(): write_mainUser : 112 7 command.c:693 command_run_line():
Debug: 113 8 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_init
Debug: 114 8 command.c:145 script_debug(): command - init ocd_init
Debug: 116 8 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target init
Debug: 117 8 command.c:145 script_debug(): command - ocd_target ocd_target init
Debug: 119 8 target.c:1281 handle_target_init_command(): Initializing targets...
Debug: 120 8 hla_target.c:357 adapter_init_target(): adapter_init_target
Debug: 121 8 command.c:366 register_command_handler(): registering 'ocd_target_request'...
Debug: 122 8 command.c:401 register_command(): command 'trace' is already registered in '<global>' context
Debug: 123 8 command.c:366 register_command_handler(): registering 'ocd_trace'...
Debug: 124 8 command.c:366 register_command_handler(): registering 'ocd_trace'...
Debug: 125 8 command.c:366 register_command_handler(): registering 'ocd_fast_load_image'...
Debug: 126 8 command.c:366 register_command_handler(): registering 'ocd_fast_load'...
Debug: 127 8 command.c:366 register_command_handler(): registering 'ocd_profile'...
Debug: 128 8 command.c:366 register_command_handler(): registering 'ocd_virt2phys'...
Debug: 129 8 command.c:366 register_command_handler(): registering 'ocd_reg'...
Debug: 130 8 command.c:366 register_command_handler(): registering 'ocd_poll'...
Debug: 131 8 command.c:366 register_command_handler(): registering 'ocd_wait_halt'...
Debug: 132 8 command.c:366 register_command_handler(): registering 'ocd_halt'...
Debug: 133 8 command.c:366 register_command_handler(): registering 'ocd_resume'...
Debug: 134 8 command.c:366 register_command_handler(): registering 'ocd_reset'...
Debug: 135 8 command.c:366 register_command_handler(): registering 'ocd_soft_reset_halt'...
Debug: 136 8 command.c:366 register_command_handler(): registering 'ocd_step'...
Debug: 137 8 command.c:366 register_command_handler(): registering 'ocd_mdw'...
Debug: 138 8 command.c:366 register_command_handler(): registering 'ocd_mdh'...
Debug: 139 8 command.c:366 register_command_handler(): registering 'ocd_mdb'...
Debug: 140 8 command.c:366 register_command_handler(): registering 'ocd_mww'...
Debug: 141 8 command.c:366 register_command_handler(): registering 'ocd_mwh'...
Debug: 142 8 command.c:366 register_command_handler(): registering 'ocd_mwb'...
Debug: 143 8 command.c:366 register_command_handler(): registering 'ocd_bp'...
Debug: 144 8 command.c:366 register_command_handler(): registering 'ocd_rbp'...
Debug: 145 8 command.c:366 register_command_handler(): registering 'ocd_wp'...
Debug: 146 8 command.c:366 register_command_handler(): registering 'ocd_rwp'...
Debug: 147 8 command.c:366 register_command_handler(): registering 'ocd_load_image'...
Debug: 148 8 command.c:366 register_command_handler(): registering 'ocd_dump_image'...
Debug: 149 8 command.c:366 register_command_handler(): registering 'ocd_verify_image'...
Debug: 150 8 command.c:366 register_command_handler(): registering 'ocd_test_image'...
Debug: 151 8 command.c:366 register_command_handler(): registering 'ocd_reset_nag'...
Debug: 152 8 command.c:366 register_command_handler(): registering 'ocd_ps'...
Debug: 153 8 command.c:366 register_command_handler(): registering 'ocd_test_mem_access'...
Debug: 154 8 hla_interface.c:108 hl_interface_init(): hl_interface_init
Debug: 155 8 hla_layout.c:85 hl_layout_init(): hl_layout_init
Info : 156 8 core.c:1371 adapter_init(): This adapter doesn't support configurable speed
Debug: 157 8 openocd.c:132 handle_init_command(): Debug Adapter init complete
Debug: 158 8 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_transport init
Debug: 159 8 command.c:145 script_debug(): command - ocd_transport ocd_transport init
Debug: 161 8 transport.c:240 handle_transport_init(): handle_transport_init
Debug: 162 8 hla_transport.c:148 hl_transport_init(): hl_transport_init
Debug: 163 8 hla_transport.c:165 hl_transport_init(): current transport hla_swd
Debug: 164 8 hla_interface.c:44 hl_interface_open(): hl_interface_open
Debug: 165 8 hla_layout.c:42 hl_layout_open(): hl_layout_open
Debug: 166 8 stlink_usb.c:1559 stlink_usb_open(): stlink_usb_open
Debug: 167 8 stlink_usb.c:1574 stlink_usb_open(): transport: 1 vid: 0x0483 pid: 0x3748
Info : 168 19 stlink_usb.c:454 stlink_usb_version(): STLINK v2 JTAG v14 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : 169 19 stlink_usb.c:1671 stlink_usb_open(): using stlink api v2
Debug: 170 20 stlink_usb.c:622 stlink_usb_init_mode(): MODE: 0x02
Info : 171 25 stlink_usb.c:486 stlink_usb_check_voltage(): Target voltage: 2.875206
Debug: 172 25 stlink_usb.c:677 stlink_usb_init_mode(): MODE: 0x01
Debug: 173 29 stlink_usb.c:716 stlink_usb_init_mode(): MODE: 0x02
Debug: 174 33 stlink_usb.c:1710 stlink_usb_open(): Using TAR autoincrement: 4096
Debug: 175 33 hla_interface.c:129 hl_interface_execute_queue(): hl_interface_execute_queue: ignored
Debug: 176 33 core.c:717 jtag_add_reset(): SRST line released
Debug: 177 33 core.c:741 jtag_add_reset(): TRST line released
Debug: 178 33 core.c:321 jtag_call_event_callbacks(): jtag event: TAP reset
Debug: 179 33 hla_interface.c:69 hl_interface_init_target(): hl_interface_init_target
Debug: 180 35 stlink_usb.c:741 stlink_usb_idcode(): IDCODE: 0x2BA01477
Debug: 181 35 openocd.c:145 handle_init_command(): Examining targets...
Debug: 182 35 target.c:1397 target_call_event_callbacks(): target event 21 (examine-start)
Debug: 183 35 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe000ed00 4 1
Debug: 184 39 target.c:2060 target_read_u32(): address: 0xe000ed00, value: 0x410fc241
Debug: 185 39 cortex_m.c:1804 cortex_m_examine(): Cortex-M4 r0p1 processor detected
Debug: 186 39 cortex_m.c:1805 cortex_m_examine(): cpuid: 0x410fc241
Debug: 187 39 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe000ef40 4 1
Debug: 188 43 target.c:2060 target_read_u32(): address: 0xe000ef40, value: 0x10110021
Debug: 189 43 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe000ef44 4 1
Debug: 190 47 target.c:2060 target_read_u32(): address: 0xe000ef44, value: 0x11000011
Debug: 191 47 cortex_m.c:1813 cortex_m_examine(): Cortex-M4 floating point feature FPv4_SP found
Debug: 192 47 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe0002000 4 1
Debug: 193 51 target.c:2060 target_read_u32(): address: 0xe0002000, value: 0x00000260
Debug: 194 51 target.c:2148 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 195 51 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0002008 4 1
Debug: 196 58 target.c:2148 target_write_u32(): address: 0xe000200c, value: 0x00000000
Debug: 197 58 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe000200c 4 1
Debug: 198 61 target.c:2148 target_write_u32(): address: 0xe0002010, value: 0x00000000
Debug: 199 61 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0002010 4 1
Debug: 200 64 target.c:2148 target_write_u32(): address: 0xe0002014, value: 0x00000000
Debug: 201 64 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0002014 4 1
Debug: 202 68 target.c:2148 target_write_u32(): address: 0xe0002018, value: 0x00000000
Debug: 203 68 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0002018 4 1
Debug: 204 72 target.c:2148 target_write_u32(): address: 0xe000201c, value: 0x00000000
Debug: 205 72 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe000201c 4 1
Debug: 206 76 target.c:2148 target_write_u32(): address: 0xe0002020, value: 0x00000000
Debug: 207 76 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0002020 4 1
Debug: 208 80 target.c:2148 target_write_u32(): address: 0xe0002024, value: 0x00000000
Debug: 209 80 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0002024 4 1
Debug: 210 84 cortex_m.c:1850 cortex_m_examine(): FPB fpcr 0x260, numcode 6, numlit 2
Debug: 211 84 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe0001000 4 1
Debug: 212 89 target.c:2060 target_read_u32(): address: 0xe0001000, value: 0x40000000
Debug: 213 89 target.c:2148 target_write_u32(): address: 0xe0001028, value: 0x00000000
Debug: 214 89 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0001028 4 1
Debug: 215 93 target.c:2148 target_write_u32(): address: 0xe0001038, value: 0x00000000
Debug: 216 93 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0001038 4 1
Debug: 217 97 target.c:2148 target_write_u32(): address: 0xe0001048, value: 0x00000000
Debug: 218 97 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0001048 4 1
Debug: 219 101 target.c:2148 target_write_u32(): address: 0xe0001058, value: 0x00000000
Debug: 220 101 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe0001058 4 1
Debug: 221 105 cortex_m.c:1761 cortex_m_dwt_setup(): DWT dwtcr 0x40000000, comp 4, watch/trigger
Info : 222 105 cortex_m.c:1859 cortex_m_examine(): stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Debug: 223 105 target.c:1397 target_call_event_callbacks(): target event 22 (examine-end)
Debug: 224 105 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_flash init
Debug: 225 105 command.c:145 script_debug(): command - ocd_flash ocd_flash init
Debug: 226 107 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe000edf8 4 1
Debug: 227 111 target.c:2060 target_read_u32(): address: 0xe000edf8, value: 0x00000000
Debug: 228 111 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 229 113 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 0 value 0x0
Debug: 230 113 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 231 115 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 232 115 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 233 117 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 2 value 0x0
Debug: 234 117 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 235 119 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 3 value 0x0
Debug: 236 119 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 237 123 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 4 value 0x0
Debug: 238 123 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 239 125 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 240 125 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 241 127 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 242 127 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 243 129 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 7 value 0x0
Debug: 244 129 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 245 131 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 8 value 0x0
Debug: 246 131 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 247 133 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 9 value 0x0
Debug: 248 133 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 249 135 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 10 value 0x0
Debug: 250 135 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 251 137 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 11 value 0x0
Debug: 252 137 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 253 139 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 254 139 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 255 141 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 13 value 0x2001ffe0
Debug: 256 141 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 257 143 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 258 143 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 259 145 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 15 value 0x8001c1c
Debug: 260 145 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 261 147 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 16 value 0x1000003
Debug: 262 147 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 263 149 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 17 value 0x2001ffe0
Debug: 264 149 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 265 151 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 18 value 0x0
Debug: 266 151 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 267 155 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 268 155 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 269 157 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 270 157 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 271 159 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 272 159 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 273 161 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 274 164 hla_target.c:447 adapter_debug_entry(): entered debug state in core mode: Handler at PC 0x08001c1c, target->state: halted
Debug: 275 164 target.c:1397 target_call_event_callbacks(): target event 0 (gdb-halt)
Debug: 276 164 target.c:1397 target_call_event_callbacks(): target event 1 (halted)
Debug: 277 164 hla_target.c:486 adapter_poll(): halted: PC: 0x08001c1c
Debug: 279 164 tcl.c:873 handle_flash_init_command(): Initializing flash devices...
Debug: 280 164 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 281 164 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 282 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 283 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 284 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 285 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 286 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 287 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 288 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 289 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 290 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 291 165 command.c:366 register_command_handler(): registering 'ocd_flash'...
Debug: 292 165 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_mflash init
Debug: 293 165 command.c:145 script_debug(): command - ocd_mflash ocd_mflash init
Debug: 295 166 mflash.c:1379 handle_mflash_init_command(): Initializing mflash devices...
Debug: 296 166 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_nand init
Debug: 297 166 command.c:145 script_debug(): command - ocd_nand ocd_nand init
Debug: 299 168 tcl.c:497 handle_nand_init_command(): Initializing NAND devices...
Debug: 300 168 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_pld init
Debug: 301 168 command.c:145 script_debug(): command - ocd_pld ocd_pld init
Debug: 303 170 pld.c:207 handle_pld_init_command(): Initializing PLDs...
Info : 304 27913 server.c:83 add_connection(): accepting 'telnet' connection from 4444
Debug: 305 31182 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_reset halt
Debug: 306 31182 command.c:145 script_debug(): command - reset ocd_reset halt
Debug: 308 31185 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_target names
Debug: 309 31185 command.c:145 script_debug(): command - ocd_target ocd_target names
Debug: 310 31185 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event reset-start
Debug: 311 31185 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event reset-start
Debug: 312 31185 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag arp_init-reset
Debug: 313 31185 command.c:145 script_debug(): command - ocd_jtag ocd_jtag arp_init-reset
Debug: 315 31185 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu cget -chain-position
Debug: 316 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu cget -chain-position
Debug: 317 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32f4x.cpu
Debug: 318 31186 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32f4x.cpu
Debug: 319 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event examine-start
Debug: 320 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event examine-start
Debug: 321 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu arp_examine
Debug: 322 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu arp_examine
Debug: 323 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event examine-end
Debug: 324 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event examine-end
Debug: 325 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event reset-assert-pre
Debug: 326 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event reset-assert-pre
Debug: 327 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu cget -chain-position
Debug: 328 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu cget -chain-position
Debug: 329 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32f4x.cpu
Debug: 330 31186 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32f4x.cpu
Debug: 331 31186 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu arp_reset assert 1
Debug: 332 31186 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu arp_reset assert 1
Debug: 333 31186 target.c:1718 target_free_all_working_areas_restore(): freeing all working areas
Debug: 334 31186 hla_target.c:499 adapter_assert_reset(): adapter_assert_reset
Debug: 335 31195 stlink_usb.c:909 stlink_usb_reset(): RESET: 0x00000080
Debug: 336 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event reset-assert-post
Debug: 337 31195 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event reset-assert-post
Debug: 338 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event reset-deassert-pre
Debug: 339 31195 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event reset-deassert-pre
Debug: 340 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu cget -chain-position
Debug: 341 31195 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu cget -chain-position
Debug: 342 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32f4x.cpu
Debug: 343 31195 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32f4x.cpu
Debug: 344 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu arp_reset deassert 1
Debug: 345 31195 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu arp_reset deassert 1
Debug: 346 31195 target.c:1718 target_free_all_working_areas_restore(): freeing all working areas
Debug: 347 31195 hla_target.c:562 adapter_deassert_reset(): adapter_deassert_reset
Debug: 348 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event reset-deassert-post
Debug: 349 31195 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event reset-deassert-post
Debug: 350 31195 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu cget -chain-position
Debug: 351 31196 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu cget -chain-position
Debug: 352 31196 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_jtag tapisenabled stm32f4x.cpu
Debug: 353 31196 command.c:145 script_debug(): command - ocd_jtag ocd_jtag tapisenabled stm32f4x.cpu
Debug: 354 31196 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu arp_waitstate halted 1000
Debug: 355 31196 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu arp_waitstate halted 1000
Debug: 356 31197 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe000edf8 4 1
Debug: 357 31201 target.c:2060 target_read_u32(): address: 0xe000edf8, value: 0x00000000
Debug: 358 31201 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 359 31203 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 0 value 0x0
Debug: 360 31203 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 361 31205 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 362 31205 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 363 31207 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 2 value 0x0
Debug: 364 31207 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 365 31210 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 3 value 0x0
Debug: 366 31210 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 367 31215 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 4 value 0x0
Debug: 368 31215 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 369 31217 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 370 31217 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 371 31219 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 372 31219 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 373 31224 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 7 value 0x0
Debug: 374 31224 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 375 31226 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 8 value 0x0
Debug: 376 31226 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 377 31228 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 9 value 0x0
Debug: 378 31228 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 379 31230 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 10 value 0x0
Debug: 380 31230 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 381 31232 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 11 value 0x0
Debug: 382 31232 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 383 31234 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 384 31234 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 385 31236 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 13 value 0x20020000
Debug: 386 31236 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 387 31242 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 14 value 0xffffffff
Debug: 388 31242 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 389 31244 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 15 value 0x8002080
Debug: 390 31244 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 391 31246 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 16 value 0x0
Debug: 392 31246 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 393 31248 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 17 value 0x20020000
Debug: 394 31248 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 395 31250 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 18 value 0x0
Debug: 396 31250 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 397 31252 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 398 31252 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 399 31254 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 400 31254 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 401 31256 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 402 31256 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 403 31258 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 404 31260 hla_target.c:447 adapter_debug_entry(): entered debug state in core mode: Thread at PC 0x08002080, target->state: halted
Debug: 405 31260 target.c:1397 target_call_event_callbacks(): target event 0 (gdb-halt)
Debug: 406 31260 target.c:1397 target_call_event_callbacks(): target event 1 (halted)
User : 407 31260 target.c:1770 target_arch_state(): target state: halted
User : 408 31260 armv7m.c:501 armv7m_arch_state(): target halted due to debug-request, current mode: Thread
xPSR: 00000000 pc: 0x08002080 msp: 0x20020000
Debug: 409 31260 hla_target.c:486 adapter_poll(): halted: PC: 0x08002080
Debug: 410 31260 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu curstate
Debug: 411 31260 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu curstate
Debug: 412 31260 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_stm32f4x.cpu invoke-event reset-end
Debug: 413 31260 command.c:145 script_debug(): command - ocd_stm32f4x.cpu ocd_stm32f4x.cpu invoke-event reset-end
Debug: 414 32526 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_step
Debug: 415 32526 command.c:145 script_debug(): command - step ocd_step
Debug: 417 32529 target.c:2702 handle_step_command(): -
Debug: 418 32529 hla_target.c:703 adapter_step(): adapter_step
Debug: 419 32529 armv7m.c:127 armv7m_restore_context():
Debug: 420 32529 target.c:2148 target_write_u32(): address: 0xe000edf8, value: 0x00000000
Debug: 421 32529 hla_target.c:780 adapter_write_memory(): adapter_write_memory 0xe000edf8 4 1
Debug: 422 32533 target.c:1397 target_call_event_callbacks(): target event 2 (resumed)
Debug: 423 32541 hla_target.c:766 adapter_read_memory(): adapter_read_memory 0xe000edf8 4 1
Debug: 424 32545 target.c:2060 target_read_u32(): address: 0xe000edf8, value: 0x00000000
Debug: 425 32545 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 426 32547 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 0 value 0x0
Debug: 427 32547 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 428 32549 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 1 value 0x0
Debug: 429 32549 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 430 32552 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 2 value 0x0
Debug: 431 32552 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 432 32554 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 3 value 0x0
Debug: 433 32554 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 434 32556 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 4 value 0x0
Debug: 435 32556 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 436 32558 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 5 value 0x0
Debug: 437 32558 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 438 32560 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 6 value 0x0
Debug: 439 32560 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 440 32562 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 7 value 0x0
Debug: 441 32562 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 442 32564 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 8 value 0x0
Debug: 443 32564 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 444 32566 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 9 value 0x0
Debug: 445 32566 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 446 32568 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 10 value 0x0
Debug: 447 32568 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 448 32570 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 11 value 0x0
Debug: 449 32570 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 450 32572 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 12 value 0x0
Debug: 451 32572 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 452 32574 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 13 value 0x2001ffe0
Debug: 453 32574 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 454 32576 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 14 value 0xfffffff9
Debug: 455 32576 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 456 32578 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 15 value 0x8001c1c
Debug: 457 32578 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 458 32580 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 16 value 0x1000003
Debug: 459 32580 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 460 32582 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 17 value 0x2001ffe0
Debug: 461 32582 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 462 32584 hla_target.c:75 adapter_load_core_reg_u32(): load from core reg 18 value 0x0
Debug: 463 32584 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 464 32586 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 465 32586 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 466 32588 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 467 32588 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 468 32590 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 469 32590 hla_target.c:60 adapter_load_core_reg_u32(): adapter_load_core_reg_u32
Debug: 470 32592 hla_target.c:140 adapter_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 471 32594 hla_target.c:447 adapter_debug_entry(): entered debug state in core mode: Handler at PC 0x08001c1c, target->state: halted
Debug: 472 32594 target.c:1397 target_call_event_callbacks(): target event 0 (gdb-halt)
Debug: 473 32594 target.c:1397 target_call_event_callbacks(): target event 1 (halted)
User : 474 32594 target.c:1770 target_arch_state(): target state: halted
User : 475 32594 armv7m.c:501 armv7m_arch_state(): target halted due to single-step, current mode: Handler HardFault
xPSR: 0x01000003 pc: 0x08001c1c msp: 0x2001ffe0
Info : 476 32594 hla_target.c:752 adapter_step(): halted: PC: 0x08001c1c
After initializing openocd, I performed a reset halt followed by a step instruction. I can't understand why PC doesn't start and remain at 0x08002080, but instead goes to 0x08001c1c, which is the location of the hard fault handler
