- Wed Jul 26, 2006 1:27 am
#16253
I am encountering difficulties when building openocd from svn sources on a cygwin host. Since I don't have svn access at work, I am currently using revision 60 that I had downloaded some time ago at home.
Basically the issue is that the build process (bootstrap, configure and install) works without any problem.
However, when trying to use the finally generated executable with an olimex wiggler clone, I get the error message
missing priviledges for direct io ()
in parport.c:289.
When using a pre-compiled binary (openocd-pp) from the admontec company I succeed in getting the system working. However, using a pre-compiled binary is not much of a help if you plan to work on the open-ocd code and (maybe) contribute.
Any hint on how to overcome the difficulty would appreciated.
Bjoern Haase
in parport.c:289.
Bjoern Haase
