Open source ARM Debugger
By tecnologia
#16204
We are starting to test a development environment using the components listed below. The problem that we are facing is that we can't get the OpenOCD to halt the target. At times that we can we are enabled to inspect the registers, alter the registers, load a binary and execute it. When we try to step the program it works for about 3 steps after that it looses control over the target. For me it seems like a problem related to the JTAG resets, thou I have already tried some combinations parameters of the reset_config <signals> [combination] [trst_type] [srst_type].
I have listed the configuration file, the command line used and the log of the openOCD.
At this time we have exausted our knowledge and if someone can help we would appreciate.
environment:
SuSE Linux 10, kernel 2.6.13-15-default
Open On-Chip Debugger (2006-07-15 12:00 CEST)
Amontec JTagkey
libftd2xx0.4.10.tar.gz
Cirrus EDB9302 kit, uses EP9302 (ARM920T) microcontroller
OpenOCD arm9_ftd2xx.cfg:
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ftd2xx
ftd2xx_device_desc "Amontec JTAGkey A"
ftd2xx_layout "jtagkey"
ftd2xx_vid_pid 0x0403 0xcff8
jtag_speed 1
#use combined on interfaces or targets that can't set TRST/SRST separately
reset_config trst_and_srst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup halt
#target <type> <endianess> <reset mode>
target arm920t little run_and_halt
run_and_halt_time 0 30
Starting the OpenOCD Server
openocd -f doc/configs/arm9_ftd2xx.cfg -d 3 -l openocd.log
OpenOCD telnet command line
> reset
> halt
requesting target halt...
> poll
target state: running
> reset halt
> reset halt
openocd.log
Debug: embeddedice.c:155 embeddedice_read_reg_w_check(): 1
Debug: target.c:1275 handle_reset_command():
Debug: arm7_9_common.c:649 arm7_9_assert_reset(): target->state: running
Debug: jtag.c:234 jtag_call_event_callbacks(): jtag event: 0
Debug: jtag.c:1044 jtag_reset_callback():
Debug: ftd2xx.c:614 jtagkey_reset(): trst: 0, srst: 1, high_output: 0x01, high_direction: 0x0f
Debug: arm7_9_common.c:775 arm7_9_halt(): target->state: reset
Debug: embeddedice.c:251 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:251 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:712 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:234 jtag_call_event_callbacks(): jtag event: 2
Debug: ftd2xx.c:614 jtagkey_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Another Try
> halt
target already halted
> resume
Target 0 resumed
> halt
openocd.log
Debug: arm920t.c:291 arm920t_read_cp15_interpreted(): opcode: ee150f30, value: 00000010
Debug: arm920t.c:291 arm920t_read_cp15_interpreted(): opcode: ee160f10, value: fffff7ff
Debug: arm920t.c:291 arm920t_read_cp15_interpreted(): opcode: ee160f30, value: 00000000
Debug: target.c:439 target_call_event_callbacks(): target event 0
Info: server.c:67 add_connection(): accepted 'telnet' connection from 0
Debug: target.c:1201 handle_halt_command():
Debug: arm7_9_common.c:775 arm7_9_halt(): target->state: halted
Warning: arm7_9_common.c:779 arm7_9_halt(): target was already halted
Debug: target.c:1319 handle_resume_command():
Debug: arm7_9_common.c:1281 arm7_9_resume():
Debug: arm7_9_common.c:1082 arm7_9_restore_context():
Debug: arm920t.c:381 arm920t_write_cp15_interpreted(): opcode: ee050f10, value: 000000ff, address: 00000000
Debug: arm920t.c:381 arm920t_write_cp15_interpreted(): opcode: ee050f30, value: 00000010, address: 00000000
Debug: arm920t.c:381 arm920t_write_cp15_interpreted(): opcode: ee060f10, value: fffff7ff, address: 00000000
Debug: arm920t.c:381 arm920t_write_cp15_interpreted(): opcode: ee060f30, value: 00000000, address: 00000000
Debug: arm7_9_common.c:1098 arm7_9_restore_context(): examining User mode
Debug: arm7_9_common.c:1112 arm7_9_restore_context(): examining dirty reg: r0
Debug: arm7_9_common.c:1112 arm7_9_restore_context(): examining dirty reg: pc
Debug: arm7_9_common.c:1160 arm7_9_restore_context(): writing register 0 of mode User with value 0x8093009c
Debug: arm7_9_common.c:1098 arm7_9_restore_context(): examining FIQ mode
Debug: arm7_9_common.c:1098 arm7_9_restore_context(): examining IRQ mode
Debug: arm7_9_common.c:1098 arm7_9_restore_context(): examining Supervisor mode
Debug: arm7_9_common.c:1098 arm7_9_restore_context(): examining Abort mode
Debug: arm7_9_common.c:1098 arm7_9_restore_context(): examining Undefined mode
Debug: arm7_9_common.c:1199 arm7_9_restore_context(): writing PC with value 0x00000000
Debug: embeddedice.c:251 embeddedice_write_reg(): 0: 0x00000000
Debug: target.c:439 target_call_event_callbacks(): target event 1
Debug: arm7_9_common.c:1384 arm7_9_resume(): target resumed
Debug: arm7_9_common.c:775 arm7_9_halt(): target->state: running
By tecnologia
#16207
Using the config below we had some improvements, thou not always we can get control over the board:
we altered the: reset_config trst_only
arm9_ftd2xx.cfg
telnet_port 4444
gdb_port 3333
#interface
interface ftd2xx
jtag_speed 1
#jtag scan chain
daemon_startup halt
target arm920t little reset_halt 0
#working_area 0 0x200000 0x4000 backup
#run_and_halt_time 0 30
#flash configuration
#flash bank <driver> <base> <size> <chip_width> <bus_width> [driver_options ...]
#flash bank cfi 0x10000000 0x800000 2 2 0
By ntfreak
#16324
What pins are connected to trst and srst on your target board ? Are these pins connected together, independant, etc ?
Openocd can use many combinations of srst and trst but only if your hardware matches what it expects.
Cheers
Spen
By tecnologia
#16340
in the EDB9302 kit board the trst is connected to the trst in the EP9302. The rst is connected to the RSTON pin, which is a reset pin in the EP9302, thou it may be disconnected from that pin via a jumper. In all our tests using the option trst was the one that gave the best results, thou we can debug sometimes it halts and it is necessary to reset the openocd. It seems that we or not in control of the CPU.
By Dominic
#16342
Could you please send me full debug output to Dominic.Rath <at> gmx.de?
I suspect there might be a problem with the reset circuitry, but would like to have a look at what happens once the OpenOCD starts up.
In general, the option "reset_config trst_and_srst" is the best solution, as it gives you full control over what the processor does. All other options are somewhat limited.
Regards,
Dominic
By tecnologia
#16343
It was a good hint, because looking at the log I found out that the option daemon_startup <'attach'|'reset'> we were using halt, which is a wrong option. If that might be the problem than our problem might be solved. I have returned the board to our distributor and now I will have to wait for our prototype board to be ready so that we can test again to come to a conclusion.
GDB version problem
Another problem that we had during the environment setup was that we were using the GDB 5.3 that came with the Cirrus's tools chain from their web site, and it didn't work along the the OpenOCD. When we figure it out we installed the GDB 6.5 and everything went fine.
Thanks Dominic.
Follows below the start of the log.
openocd.log
Warning: target.c:1242 handle_daemon_startup_command(): invalid daemon_startup configuration directive: halt
Debug: arm920t.c:721 arm920t_target_command(): chain_pos: 0, variant: (null)
Debug: jtag.c:1150 jtag_init():
Debug: ftd2xx.c:887 ftd2xx_init(): current latency timer: 2
Debug: ftd2xx.c:977 jtagkey_init(): 80 08 1b
Debug: ftd2xx.c:1034 jtagkey_init(): 82 09 0f
Debug: ftd2xx.c:143 ftd2xx_speed(): 86 01 00
Debug: jtag.c:234 jtag_call_event_callbacks(): jtag event: 1
Debug: openocd.c:98 main(): jtag init complete
Debug: openocd.c:102 main(): target init complete
Debug: openocd.c:106 main(): flash init complete
Debug: gdb_server.c:1093 gdb_init(): gdb service for target arm920t at port 3333
Debug: jtag.c:234 jtag_call_event_callbacks(): jtag event: 3
Debug: arm7_9_common.c:613 arm7_9_poll(): DBGACK set, dbg_state->value: 0xd
Warning: arm7_9_common.c:616 arm7_9_poll(): DBGACK set while target was in unknown state. Reset or initialize target before resuming
Debug: embeddedice.c:251 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:907 arm7_9_debug_entry(): target entered debug from ARM state
Debug: arm7_9_common.c:926 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug: arm7_9_common.c:967 arm7_9_debug_entry(): entered debug state at PC 0x1e274
Debug: arm920t.c:448 arm920t_post_debug_entry(): cp15_control_reg: c000107f
Debug: arm920t.c:291 arm920t_read_cp15_interpreted(): opcode: ee150f10, value: 00000005
Debug: arm920t.c:291 arm920t_read_cp15_interpreted(): opcode: ee160f10, value: fffffffc
