- Fri Feb 04, 2011 9:27 am
#119252
Hi Guys.
I am debugging an LPC1313 using the ARM-JTAG-EW with IAR 5.4. I have a couple issues that I can't seem to get around.
The first problem is I have managed to brick two boards. During the startup sequence in system_LPC1313.c there are a number of macros and defines for configuring clock speed. I discovered the hard way that the macros allow you to choose the PLL output as your system clock without giving the commands to first enable it. Once I did that, I found that I can no longer attach to the chip via ARM-JTAG-EW and only get the message ...
Fri Feb 04 09:17:39 2011: Fatal error: ERROR: Error while selecting target interface, error code -2114 (ADIv5 Debug Port invalid response) Session aborted!
This leads me to my second problem. How do I properly configure the hardware to RESET via the JTAG. The RESET pin (active low) has a 10K pull_up. When I connect it NTRST line from the ARM-JTAG-EW, it is continually pulled low and I still can't attach to the chip. Should I hook to the STRST instead?
Does anybody have a suggestion where to start to tackle my problem?
Hank
Hank
