I was lazy and didn't want to dig into the details but...
First autoprobing helped to find out the jtag id and irlen for the cpld
Code: Select allsource [find interface/olimex-arm-usb-tiny-a.cfg]
reset_config trst_and_srst
jtag_rclk 8
Output of these commands:
Code: Select allInfo : RCLK (adaptive clock speed) not supported - fallback to 8 kHz
Warn : There are no enabled taps. AUTO PROBING MIGHT NOT WORK!!
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -expected-id 0x3ba00477 ..."
Warn : AUTO auto1.tap - use "jtag newtap auto1 tap -expected-id 0x06414041 ..."
Warn : AUTO auto2.tap - use "jtag newtap auto2 tap -expected-id 0x020a10dd ..."
Warn : AUTO auto0.tap - use "... -irlen 4"
Warn : AUTO auto1.tap - use "... -irlen 5"
Warn : AUTO auto2.tap - use "... -irlen 4"
Error: IR capture error at bit 13, saw 0x3FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA211 not 0x...3
Info : JTAG tap: auto0.tap tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: auto1.tap tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0)
Info : JTAG tap: auto2.tap tap/device found: 0x020a10dd (mfg: 0x06e, part: 0x20a1, ver: 0x0)
Error: IR capture error at bit 13, saw 0x2211 not 0x...3
Warn : no gdb ports allocated as no target has been specified
There is an error with IR capture here and the same error appeared when trying to upload data to the flash with a new tap created. This error was solved by changing IRLEN in tap declaration. It is 10 bits not 4 as autoprobing states. I got the following output:
Code: Select allInfo : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0)
Info : JTAG tap: EPM240.cpld tap/device found: 0x020a10dd (mfg: 0x06e, part: 0x20a1, ver: 0x0)
Info : Halt timed out, wake up GDB.
Error: timed out while waiting for target halted
expected return code but got 'TARGET: stm32.cpu - Not halted'
Runtime error, file "openOCD_STM32E.cfg", line 14:
This error is due to reset misconfiguration. On my board SRST was not routed. After connecting SRST to the CPU everything worked just fine.
Now I have a question how to halt the CPU without using SRST. Could anyone please share any examples on how to use reset-assert event handler?
