Have questions about SparkFun's ALC PCB design services? Post them here!
By Hikmet
#246378
I'm working on the project and i want to connect two sparkfun bmp581 sensor boards to one arduino using i2c connection. Using sparkfun bmp581 library can i get data from both of them?
Thank you in advance.
By paulvha
#246380
Change the link on the board to select the other address.
Add another constructor in top of sketch : BMP581 pressureSensor_1;
define new address : uint8_t NEW_i2cAddress = BMP581_I2C_ADDRESS_SECONDARY; ( 0x46)
For the rest refer to the second BMP581 as pressureSensor_1, e.g start the second BMP581 as : while(pressureSensor_1.beginI2C(NEW_i2cAddress) != BMP5_OK)
By paulvha
#246398
I would expect so. The example compiles without errors for an ESP32 and I do not see anything fancy in the driver that worries me. BUT I can't test..as I do not own one :-)
 Topic permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
