Have questions about SparkFun's ALC PCB design services? Post them here!
By JT001
#241231
Hello! I am seeking some assistance in putting together an RFID kit for a project. I want to install RFID tags/stickers on goods inside a commercial fridge and monitor the temp and track the inventory using RFID tech. Any assistance on what parts I will need would be greatly appreciated. Thank you!
By TS-Russell
#241316
That could be tricky...the fridge will likely act as a Faraday cage for the RF signals being emitted and interfere.....you might be able to rig something up with an external antenna *routed to transmit from outside the interior of the fridge*...humidity might also be an issue
Check out https://learn.sparkfun.com/tutorials/rfid-basics and https://learn.sparkfun.com/tutorials/rf ... s-tutorial for more info
Is installing a viewport into the door an option?
By JT001
#241366
Thank you for the reply. The fridges have glass front doors if that provides any significant difference. I was thinking the antenna could either be mounted on top (external) or on the underside of the top (internal)
I'll check out the link provided.
Any other suggestions on what SparkFun components I need to get this off the ground would be awesome!
Thanks again,
JT001
 Topic permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
