Have questions about SparkFun's ALC PCB design services? Post them here!
#239875
My current setup is the ICM-20948(https://www.sparkfun.com/products/15335) being connected to a Qwiic Cable - Breadboard Jumper(https://www.sparkfun.com/products/14425) to the arduino Uno directly.
I am running the Example basic program in the library
After uncommenting the debugging line, I received data underflow for everything possible.
I have also tried to wire both SPI(Defined SPI) and I2C and both had the same result, data underflow for everything.
Due to time constraints, I will not be able to order anything new and because of the time it will take to arrive.
I currently have the arduino uno kit and 2 qwiic connect cables.
(I am sorry if this may be a repeat but the other threads weren't helpful)
#239893
I was hoping to find what might be wrong but it didn't do anything other than give me data underflow for everything.
I'm very sure the code works because I pulled it straight from the library and the IMU is sending something to the Arduino, but it all comes out as data underflow.
 Topic permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
