Have questions about SparkFun's ALC PCB design services? Post them here!
By razer512
#228245
I am trying to design a circuit for an Arduino board, or any board, does not necessarily have to be Arduino.
I am putting a mod into my vehicle for an electronic turbo using an electronic RC Jet fan (EDF). I need to activate the ESC controller for the RC motor using my vehicle's throttle position signal which operates at 0.35-4.65 volts. The BEC that activates the ESC is at about 5V.
Any ideas?
Thanks
By TS-Russell
#228257
You might be after something like https://learn.sparkfun.com/tutorials/ts ... 1615791300 - also be sure to read about how they operate here https://learn.sparkfun.com/tutorials/in ... 1615791300
Just as an aside...depending on the car and motor, it looks like most EDFs will move around the amount of air needing at max RPM...so you might not end up getting any PSI 'boost', if those numbers are close
I'd calculate the CFM your motor moves https://www.widman.biz/English/Calculators/CFM.html and compare that to the specs of your selected EDF before going further ;-)
By Munyua44
#231621
razer512 wrote: Tue Aug 31, 2021 5:39 pm Hi,
Any ideas?
am not a good fan of Arduino but as I was reading through the internet, I came across this link https://www.theengineeringprojects.com/ ... o-projects which talks a lot about how to do projects with Arduino. I think if you read through you will get some necessary insight that will guide you through your project. Thank you!!
 Topic permissions
