Have questions about SparkFun's ALC PCB design services? Post them here!
By byungjun
#228111
I'm designing circuit board with sparkfun eagle library.
After exporting the C-type connecor through cam process, I don't get the proper mouting throughhole like the Carrier board from Sparkfun.
It shows through-hole type pad instead.
Is there a way to export proper cam files in Eagle cad using this package?
I'm using Eagle6.
Regards,
Jun
By KansasBot
#228243
To make sure I understand correctly, are you looking for an SMD package or through hole?
You can use the package with "4-layer" in the title and that one is completely routed out for through hole if that's what you're looking for.
 Topic permissions
You cannot post new topics in this forum
You cannot reply to topics in this forum
