- Thu Apr 14, 2022 12:32 pm
#232614
hello,
So i hhave 2 artemis nano's, on my 4 pc's one nano has its charging led act weird when plugged in. i have no battery attached, on one pc tge led turns on immediatly and stays on, another pc it blinks very rrapidly and intermittent and another it blinks but more slowly and sorta less intermittent. my other nano does similiar blinking on one of my pcs just much less and is almost perfectly fine except for sum rare flickers on the rest. Besides that the board appears to work perfectly fine on all the pc's. My fear here is sum cap has failed etc. Hopefully i can find my inline usb port volt/amp meter because im fairly certain it must be sum variation in voltage/amp. it works perfectly fine no LED lighting at all on my raspberrypi 4 and an old laptop i have. Anyone seen this or know of any reason? Should i be nervous?
ps have u guys added arm64 to the arduino boards package yet? been using arm64 arduino for close to a year and have had no issues. The only thing required to get it to work is a arm64 toolchain, so if u guys could just throw a url into that boards file (if u havent already) i would be super appreciative its a pain in the *** to upgrade at the moment. Thank you! live you guys and your awesome products!
