- Tue Oct 26, 2021 7:57 pm
#229223
Noob with multiple questions (sorry). I have an Artemis Open Log wired to collect force values from a Honeywell FSS015WNSB force sensor via SparkFun Qwiic Scale - NAU7802. Out of the box, it is collecting data OK but it is not using the full scale. I'm calibrating it with a can of coke (385g) and it is maxing it out but it shouldn't. Per the spec sheet, it should go to 15N or about 1500g. It does record intermediate values below 385 but not above.
Questions: 1) Can adjusting the gain fix this? If so: 2) How do I confirm the gain setting? Or how do I know what library it is pulling from out of the box? 3) To make the change do I need to reinstall the firmware with an edited library? If so, I'm having problems just compiling the code. I downloaded OpenLog v1.3 from Github and tried to 'verify/compile' in Arduino 1.8.16. Yet it gives me the error below:
Any help would be appreciated. //joe
OpenLog_Artemis:132:16: error: no matching function for call to 'arduino::MbedI2C::MbedI2C(int)'
TwoWire qwiic(1); //Will use pads 8/9
In file included from C:\Users\joe\OneDrive\Documents\Arduino\libraries\SparkFun_PHT_MS8607_Arduino_Library\src/SparkFun_PHT_MS8607_Arduino_Library.h:51,
from C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\settings.h:2,
from C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:77:
C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1\libraries\Wire\src/Wire.h:24:5: note: candidate: 'arduino::MbedI2C::MbedI2C(int, int)'
MbedI2C(int sda, int scl);
C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1\libraries\Wire\src/Wire.h:24:5: note: candidate expects 2 arguments, 1 provided
OpenLog_Artemis:157:1: error: 'APM3_RTC' does not name a type; did you mean 'AP3_ERR'?
APM3_RTC myRTC; //Create instance of RTC class
AP3_ERR
OpenLog_Artemis:162:1: error: 'Uart' does not name a type; did you mean 'sqrt'?
Uart SerialLog(1, 13, 12); // Declares a Uart object called Serial1 using instance 1 of Apollo3 UART peripherals with RX on pin 13 and TX on pin 12 (note, you specify *pins* not Apollo3 pads. This uses the variant's pin map to determine the Apollo3 pad)
sqrt
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino: In function 'void loop()':
OpenLog_Artemis:325:9: error: 'SerialLog' was not declared in this scope
if (SerialLog.available())
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:325:9: note: suggested alternative: 'Serial1'
Serial1
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino: In function 'void beginQwiic()':
OpenLog_Artemis:491:9: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(settings.qwiicBusPullUps); //Just to make it really clear what pull-ups are being used, set pullups here.
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino: In function 'void enableCIPOpullUp()':
OpenLog_Artemis:548:37: error: 'AP3_GPIO_DEFAULT_PINCFG' was not declared in this scope
am_hal_gpio_pincfg_t cipoPinCfg = AP3_GPIO_DEFAULT_PINCFG;
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:548:37: note: suggested alternative: 'AP3_GPIO_MAX_PADS'
AP3_GPIO_MAX_PADS
OpenLog_Artemis:552:24: error: 'AP3_SPI_IOM' was not declared in this scope
cipoPinCfg.uIOMnum = AP3_SPI_IOM;
OpenLog_Artemis:554:3: error: 'padMode' was not declared in this scope
padMode(MISO, cipoPinCfg, &retval);
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:554:3: note: suggested alternative: 'pinMode'
pinMode
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino: In function 'void beginSerialLogging()':
OpenLog_Artemis:659:5: error: 'SerialLog' was not declared in this scope
SerialLog.begin(settings.serialLogBaudRate);
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:659:5: note: suggested alternative: 'Serial1'
Serial1
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\Sensors.ino: In function 'void getData()':
Sensors:14:7: error: 'myRTC' was not declared in this scope
myRTC.getTime();
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\Sensors.ino:14:7: note: suggested alternative: 'RTC'
myRTC.getTime();
RTC
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\Sensors.ino: In function 'void gatherDeviceValues()':
Sensors:239:19: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(0); //Disable pullups to minimize CRC issues
Sensors:241:13: error: 'SFE_UBLOX_GPS' was not declared in this scope
SFE_UBLOX_GPS *nodeDevice = (SFE_UBLOX_GPS *)temp->classPtr;
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\Sensors.ino:241:13: note: suggested alternative: 'SFE_UBLOX_GNSS'
SFE_UBLOX_GNSS
Sensors:241:28: error: 'nodeDevice' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\Sensors.ino:241:28: note: suggested alternative: 'addDevice'
addDevice
Sensors:241:57: error: expected primary-expression before ')' token
Sensors:314:19: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(settings.qwiicBusPullUps); //Re-enable pullups
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino: In function 'bool addDevice(deviceType_e, uint8_t, uint8_t, uint8_t)':
autoDetect:140:30: error: 'SFE_UBLOX_GPS' does not name a type; did you mean 'SFE_UBLOX_GNSS'?
temp->classPtr = new SFE_UBLOX_GPS;
SFE_UBLOX_GNSS
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino: In function 'bool beginQwiicDevices()':
autoDetect:300:17: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(0); //Disable pullups for u-blox comms.
autoDetect:301:11: error: 'SFE_UBLOX_GPS' was not declared in this scope
SFE_UBLOX_GPS *tempDevice = (SFE_UBLOX_GPS *)temp->classPtr;
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:301:11: note: suggested alternative: 'SFE_UBLOX_GNSS'
SFE_UBLOX_GNSS
autoDetect:301:26: error: 'tempDevice' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:301:26: note: suggested alternative: 'testDevice'
testDevice
autoDetect:301:55: error: expected primary-expression before ')' token
autoDetect:304:17: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(settings.qwiicBusPullUps); //Re-enable pullups.
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino: In function 'void configureDevice(node*)':
autoDetect:503:15: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
autoDetect:505:9: error: 'SFE_UBLOX_GPS' was not declared in this scope
SFE_UBLOX_GPS *sensor = (SFE_UBLOX_GPS *)temp->classPtr;
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:505:9: note: suggested alternative: 'SFE_UBLOX_GNSS'
SFE_UBLOX_GNSS
autoDetect:505:24: error: 'sensor' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:505:24: note: suggested alternative: 'error'
error
autoDetect:505:49: error: expected primary-expression before ')' token
autoDetect:524:15: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino: In function 'deviceType_e testDevice(uint8_t, uint8_t, uint8_t)':
autoDetect:930:15: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
autoDetect:931:9: error: 'SFE_UBLOX_GPS' was not declared in this scope
SFE_UBLOX_GPS sensor;
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:931:9: note: suggested alternative: 'SFE_UBLOX_GNSS'
SFE_UBLOX_GNSS
autoDetect:932:49: error: 'sensor' was not declared in this scope
if(settings.printDebugMessages == true) sensor.enableDebugging(); // Enable debug messages if required
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:932:49: note: suggested alternative: 'error'
error
autoDetect:933:13: error: 'sensor' was not declared in this scope
if (sensor.begin(qwiic, i2cAddress) == true) //Wire port, address
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino:933:13: note: suggested alternative: 'error'
error
autoDetect:935:17: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(settings.qwiicBusPullUps); //Re-enable pullups to prevent ghosts at 0x43 onwards
autoDetect:938:15: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(settings.qwiicBusPullUps); //Re-enable pullups for normal discovery
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\autoDetect.ino: In function 'bool setMuxPortState(uint8_t, uint8_t, TwoWire&, int)':
autoDetect
24: error: call of overloaded 'write(int)' is ambiguous
wirePort.write(0x00); // Writing these extra bytes seems key to avoiding the slippery mux problem
C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1\libraries\Wire\src/Wire.h:41:20: note: candidate: 'virtual size_t arduino::MbedI2C::write(uint8_t)'
virtual size_t write(uint8_t data);
In file included from C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/Stream.h:25,
from C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/Client.h:22,
from C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/ArduinoAPI.h:29,
from C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/Arduino.h:17,
from C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/sdk/ArduinoSDK.h:9,
from <command-line>:
C:\Users\joe\OneDrive\Documents\ArduinoData\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/Print.h:50:12: note: candidate: 'size_t arduino::Print::write(const char*)'
size_t write(const char *str) {
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino: In function 'void powerDown()':
lowerPower:37:3: error: 'power_adc_disable' was not declared in this scope
power_adc_disable(); //Power down ADC. It it started by default before setup().
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:37:3: note: suggested alternative: 'am_hal_adc_disable'
am_hal_adc_disable
lowerPower:40:3: error: 'SerialLog' was not declared in this scope
SerialLog.end();
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:40:3: note: suggested alternative: 'Serial1'
SerialLog.end();
Serial1
lowerPower:56:15: error: 'ap3_gpio_pin2pad' was not declared in this scope
if ((x != ap3_gpio_pin2pad(PIN_POWER_LOSS)) &&
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:56:15: note: suggested alternative: 'ap3_gpio_pad_t'
ap3_gpio_pad_t
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino: In function 'void goToSleep()':
lowerPower:152:3: error: 'power_adc_disable' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:152:3: note: suggested alternative: 'am_hal_adc_disable'
am_hal_adc_disable
lowerPower:155:3: error: 'SerialLog' was not declared in this scope
SerialLog.end();
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:155:3: note: suggested alternative: 'Serial1'
SerialLog.end();
Serial1
lowerPower:171:15: error: 'ap3_gpio_pin2pad' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:171:15: note: suggested alternative: 'ap3_gpio_pad_t'
ap3_gpio_pad_t
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino: In function 'void wakeFromSleep()':
lowerPower:265:3: error: 'ap3_adc_setup' was not declared in this scope
ap3_adc_setup();
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino: In function 'uint64_t rtcMillis()':
lowerPower:420:3: error: 'myRTC' was not declared in this scope
myRTC.getTime();
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\lowerPower.ino:420:3: note: suggested alternative: 'RTC'
myRTC.getTime();
RTC
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuAttachedDevices.ino: In function 'bool detectQwiicDevices()':
menuAttachedDevices:38:9: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
qwiic.setPullups(settings.qwiicBusPullUps); //Set pullups. (Redundant. beginQwiic has done this too.) If we don't have pullups, detectQwiicDevices() takes ~900ms to complete. We'll disable pullups if something is detected.
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuAttachedDevices.ino: In function 'void getUbloxDateTime(int&, int&, int&, int&, int&, int&, int&, bool&, bool&)':
menuAttachedDevices:994:17: error: 'TwoWire' {aka 'class arduino::MbedI2C'} has no member named 'setPullups'
menuAttachedDevices:996:11: error: 'SFE_UBLOX_GPS' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuAttachedDevices.ino:996:11: note: suggested alternative: 'SFE_UBLOX_GNSS'
SFE_UBLOX_GNSS
menuAttachedDevices:996:26: error: 'nodeDevice' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuAttachedDevices.ino:996:26: note: suggested alternative: 'addDevice'
addDevice
menuAttachedDevices:996:55: error: expected primary-expression before ')' token
menuAttachedDevices
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuSerialLogging.ino: In function 'void menuSerialLogging()':
menuSerialLogging:59:11: error: 'SerialLog' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuSerialLogging.ino:59:11: note: suggested alternative: 'Serial1'
Serial1
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino: In function 'void menuTimeStamp()':
menuTimeStamp:8:5: error: 'myRTC' was not declared in this scope
myRTC.getTime();
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:8:5: note: suggested alternative: 'RTC'
myRTC.getTime();
RTC
menuTimeStamp:96:24: error: 'yy' was not declared in this scope
getGPSDateTime(yy, mm, dd, h, m, s, ms, dateValid, timeValid); // Get the GPS date and time, corrected for localUTCOffset
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:96:24: note: suggested alternative: 'yn'
yn
menuTimeStamp:96:28: error: 'mm' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:96:28: note: suggested alternative: 'tm'
tm
menuTimeStamp:96:36: error: 'h' was not declared in this scope
menuTimeStamp:96:39: error: 'm' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:96:39: note: suggested alternative: 'tm'
tm
menuTimeStamp:96:42: error: 's' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:96:42: note: suggested alternative: 'sd'
sd
menuTimeStamp:96:45: error: 'ms' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:96:45: note: suggested alternative: 'msg'
msg
menuTimeStamp:125:9: error: 'yy' was not declared in this scope
yy = getNumber(menuTimeout); //Timeout after x seconds
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:125:9: note: suggested alternative: 'yn'
yn
menuTimeStamp:129:9: error: 'mm' was not declared in this scope
mm = getNumber(menuTimeout); //Timeout after x seconds
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:129:9: note: suggested alternative: 'tm'
tm
menuTimeStamp:134:23: error: 'h' was not declared in this scope
myRTC.setTime(h, m, s, 0, dd, mm, yy); //Manually set RTC
menuTimeStamp:134:26: error: 'm' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:134:26: note: suggested alternative: 'tm'
tm
menuTimeStamp:134:29: error: 's' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:134:29: note: suggested alternative: 'sd'
sd
menuTimeStamp:152:9: error: 'h' was not declared in this scope
h = getNumber(menuTimeout); //Timeout after x seconds
menuTimeStamp:155:9: error: 'm' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:155:9: note: suggested alternative: 'tm'
tm
menuTimeStamp:158:9: error: 's' was not declared in this scope
s = getNumber(menuTimeout); //Timeout after x seconds
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:158:9: note: suggested alternative: 'sd'
sd
menuTimeStamp:160:39: error: 'mm' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:160:39: note: suggested alternative: 'tm'
tm
menuTimeStamp:160:43: error: 'yy' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\menuTimeStamp.ino:160:43: note: suggested alternative: 'yn'
yn
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\productionTest.ino: In function 'void productionTest()':
productionTest:101:3: error: 'SerialLog' was not declared in this scope
SerialLog.begin(115200); // Begin the serial port using the TX and RX breakout pins
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\productionTest.ino:101:3: note: suggested alternative: 'Serial1'
Serial1
productionTest:283:9: error: 'myRTC' was not declared in this scope
myRTC.getTime(); // Read the RTC
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\productionTest.ino:283:9: note: suggested alternative: 'RTC'
RTC
productionTest:292:9: error: 'power_adc_disable' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\productionTest.ino:292:9: note: suggested alternative: 'am_hal_adc_disable'
am_hal_adc_disable
productionTest:327:9: error: 'ap3_adc_setup' was not declared in this scope
ap3_adc_setup();
productionTest:430:9: error: 'myRTC' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\productionTest.ino:430:9: note: suggested alternative: 'RTC'
RTC
productionTest:535:21: error: 'ap3_gpio_pin2pad' was not declared in this scope
C:\Users\joe\Downloads\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\OpenLog_Artemis-8d410f238505b564516e7f39e68a30e240c6a12e\Firmware\OpenLog_Artemis\productionTest.ino:535:21: note: suggested alternative: 'ap3_gpio_pad_t'
ap3_gpio_pad_t
exit status 1
AP3_ERR
sqrt
Serial1
AP3_GPIO_MAX_PADS
pinMode
Serial1
myRTC.getTime();
myRTC.getTime();
RTC
SFE_UBLOX_GNSS
addDevice
SFE_UBLOX_GNSS
SFE_UBLOX_GNSS
testDevice
SFE_UBLOX_GNSS
error
SFE_UBLOX_GNSS
error
error
autoDetect
am_hal_adc_disable
SerialLog.end();
SerialLog.end();
Serial1
ap3_gpio_pad_t
am_hal_adc_disable
SerialLog.end();
SerialLog.end();
Serial1
ap3_gpio_pad_t
ap3_adc_setup();
myRTC.getTime();
myRTC.getTime();
RTC
SFE_UBLOX_GNSS
addDevice
menuAttachedDevices
Serial1
myRTC.getTime();
myRTC.getTime();
RTC
yn
tm
tm
sd
msg
yn
tm
tm
sd
tm
sd
tm
yn
Serial1
RTC
am_hal_adc_disable
ap3_adc_setup();
RTC
ap3_gpio_pad_t
exit status 1
