By prittenhouse
#228641
I am trying to compile the 'BasicReadings' example for the LIS2DH12 with my Board set to the Artemis Dev Kit. I am getting a bunch of multiple definition errors like:
c:/users/lyla caudle/appdata/local/arduino15/packages/sparkfun/tools/arm-none-eabi-gcc/8-2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Lyla Caudle\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1\variants\SFE_ARTEMIS_DK/mbed/libmbed-os.a(lis2dh12_reg.o): in function `lis2dh12_write_reg':
lis2dh12_reg.c:(.text.lis2dh12_write_reg+0x0): multiple definition of `lis2dh12_write_reg'; libraries\SparkFun_LIS2DH12_Arduino_Library\lis2dh12_reg.cpp.o:lis2dh12_reg.cpp:(.text.lis2dh12_write_reg+0x0): first defined here
If I am reading this right it looks like the apollo3 package has its own copy of the library which is creating the conflict.
Any suggestions on how to resolve it?
Thanks,
Phil
By prittenhouse
#228653
Yah, I saw that post but I don't think that's the problem here. I don't see any includes like that in the demo code. Presumably this code normally compiles for other boards so I suspect it is a problem specific to the Artemis
By prittenhouse
#228673
prittenhouse wrote: Fri Sep 24, 2021 1:53 pm Presumably this code normally compiles for other boards so I suspect it is a problem specific to the Artemis
Sorry, I meant to say I suspect the problem is specific to the Apollo 3 Arduino library. Has anyone build this example with the latest libraries recently?
Thanks,
Phil
By prittenhouse
#228674
Hmmmm... it seems I can't edit my post. Let me try again
I meant to say I suspect the problem is related to the Artemis Arduino library. Has anyone built this example with the latest libraries recently? The Getting Started guide https://learn.sparkfun.com/tutorials/ge ... e-overview says to install the Sparkfun LIS2DH12 library but I'm wondering if the two libraries are not compatible.
 Topic permissions
