- Fri Aug 27, 2021 5:39 am
#228148
Hello all,
A disclamer: I'm new here and tried my best to look at everything I could find to solve this problem before posting here.
Just received the OLA kit and I'm trying to make a project similar to the Geologger but using the Sparkfun ADS1015.
I first wanted to check if I was able to compile and upload to the OpenLog_Artemis. I was unsuccessful at that.
Always using the Sparkfun RedBoard Artemis ATP as the board and having downloaded all the libraries using the links in the OpenLog_Artemis.ino file, I tried compiling the code.
It failed giving me this error :
I attributed it to not having the right board settings because I used the "Additional Board Manager URL" :
https://raw.githubusercontent.com/spark ... index.json
from https://learn.sparkfun.com/tutorials/ar ... stallation
Looking around I found the other "Additional Board Manager URL" :
from https://github.com/sparkfun/Arduino_Apo ... ecommended
And I updated the SparkFun Apollo3 Boards to the latest version being : 2.1.1
This solved the problem of the non-definition but in the end the error now is :
As I see that others can compile and upload to the OLA, I am would like to know if someone else had this problem and solved it. I might just be missing an obvious error on my part. Thank for your help and whatever advice your give me to solve my problem.
PS: The link to the OLA REPO ZIP on https://github.com/sparkfun/OpenLog_Art ... UPGRADE.md is showing a "404: Not Found".
exit status 1
'SERIAL_BUFFER_SIZE' was not declared in this scope
During the compilation, those notes/warning were shown: exit status 1
Error compiling for board RedBoard Artemis ATP.
C:\Users\XXXXX\Downloads\OpenLog_Artemis-2.0\Firmware\OpenLog_Artemis\zmodem_sz.cpp:177: warning: "zperr" redefined
#define zperr(a, ... )
In file included from C:\Users\XXXXX\Downloads\OpenLog_Artemis-2.0\Firmware\OpenLog_Artemis\zmodem_sz.cpp:66:
C:\Users\XXXXX\Downloads\OpenLog_Artemis-2.0\Firmware\OpenLog_Artemis\zmodem_zm.h:49: note: this is the location of the previous definition
#define zperr(...)
In file included from C:\Users\XXXXX\Downloads\OpenLog_Artemis-2.0\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:273:
C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Button_and_Qwiic_Switch_Library\src/SparkFun_Qwiic_Button.h:29: warning: "DEFAULT_ADDRESS" redefined
#define DEFAULT_ADDRESS 0x6F //default I2C address of the button
In file included from C:\Users\XXXXX\Downloads\OpenLog_Artemis-2.0\Firmware\OpenLog_Artemis\OpenLog_Artemis.ino:268:
C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_MicroPressure_Library\src/SparkFun_MicroPressure.h:9: note: this is the location of the previous definition
#define DEFAULT_ADDRESS 0x18
I tried going trough all the versions of "SparkFun Apollo3 Boards" from 1.2.1 up to 2.1.1, deleting the folder each time but the problem persists with variation from the problem.C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20\src\SparkFun_Qwiic_Humidity_AHT20.cpp: In member function 'bool AHT20::initialize()':
C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20\src\SparkFun_Qwiic_Humidity_AHT20.cpp:125:25: error: call of overloaded 'write(int)' is ambiguous
_i2cPort->write(0x00);
In file included from C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20\src/SparkFun_Qwiic_Humidity_AHT20.h:26,
from C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20\src\SparkFun_Qwiic_Humidity_AHT20.cpp:26:
C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1\libraries\Wire\src/Wire.h:41:20: note: candidate: 'virtual size_t arduino::MbedI2C::write(uint8_t)'
virtual size_t write(uint8_t data);
In file included from C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/Stream.h:25,
from C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/Client.h:22,
from C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/ArduinoAPI.h:29,
from C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/Arduino.h:17,
from C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/sdk/ArduinoSDK.h:9,
from <command-line>:
C:\Users\XXXXX\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.1/cores/arduino/mbed-bridge/core-api/api/Print.h:50:12: note: candidate: 'size_t arduino::Print::write(const char*)'
size_t write(const char *str) {
C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20\src\SparkFun_Qwiic_Humidity_AHT20.cpp: In member function 'bool AHT20::triggerMeasurement()':
C:\Users\XXXXX\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20\src\SparkFun_Qwiic_Humidity_AHT20.cpp:136:25: error: call of overloaded 'write(int)' is ambiguous
