- Sun May 16, 2021 5:54 am
#225935
A novice question.
I've uploaded the LSM9DS1_Basic_SPI example to the RedBoard Artemis ATP with no errors.
When the LSM9DS1 is disconnected from the ATP the power LED on the ATP is on and I correctly get the following message via serial:
Opening port
Port open
Failed to communicate with LSM9DS1.
Double-check wiring.
Default settings in this sketch will work for an out of the box LSM9DS1 Breakout, but may need to be modified if the board jumpers are.
When I connect the LSM9DS1 the power LED on the ATP stays off and the serial port fails to open with the following message:
Opening port
Debug off
Port failed to open
I plugged in an external power supply to see whether that made any difference but it didn't.
Any ideas what is wrong?
Thanks
Opening port
Port open
Opening port
Debug off
Port failed to open
Thanks
Thanks. Stephen
