By kevin_s
#224706
I have the Edge and Serial (DEV-15170) and Serial Basic Board (DEV-14050) to talk to it. I've configured the Artemis board and libraries in my Arduino IDE (v1.8.13) but am unable to load any code to the Edge. The IDE times out trying to write to the serial port.
Logging from IDE:
Image from 0x0 to 0x270c will be loaded at 0x20000
Connecting over serial port COM5...
Fail
Fail
Fail
Tries = 3
Upload failed
Any ideas? I've reviewed the hardware hookup guides and the Programming the Sparkfun Edge Board with Arduino guide and am pretty sure I didn't miss anything.
TIA,
Kevin
By Airheadbit
#232222
Artemis SVL Bootloader
Script version 1.7
Phase: Setup
Cleared startup blip
Failed to enter bootload phase
Phase: Setup
Phase: Setup
Target failed to enter bootload mode. Verify the right COM port is selected and that your board has the SVL bootloader.
So I have to ask, does the Edge have the SVL bootloader installed? How do I tell? I lowered the baud to 115200 then to 57600, each time RST then 14 release RST then release 14 - same error
Tried 'burning a bootloader'
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:329)
at processing.app.Editor.lambda$handleBurnBootloader$61(Editor.java:2385)
at java.lang.Thread.run(Thread.java:748)
Error while burning bootloader.
All I want to see is blinky blink. nope.
 Topic permissions
