#220954
Paul,
I purchased the following parts
1. SparkFun OpenLog Artemis (2)
2. Qwiic Cable - 500mm (2)
3. Qwiic Pressure/Humidity/Temp (PHT) Sensor - MS8607
4. Qwiic PT100 - ADS122C04
The OpenLog Artemis and Qwiic PT100 - ADS122C04 work fine.
Neither OpenLog Artemis recognizes the Qwiic Pressure/Humidity/Temp (PHT) Sensor - MS8607.
The terminal messages for the two OpenLogs when the MS8607 is connected (red power LED is on) are
Artemis OpenLog v1.5
Logging to: dataLog00011.TXT
Logging to: serialLog00020.TXT
SD card online
Data logging online
Serial logging online
IMU online
No Qwiic devices detected
Artemis OpenLog v1.7
Logging to: dataLog00012.TXT
SD card online
Data logging online
IMU online
Identifying Qwiic Muxes...
Identifying Qwiic Devices...
It is my understanding that the MS8607 should be automatically detected.
My question is – Should I see the MS8607 attached or do I have to change/add settings or commands? When I select
6) Detect / Configure Attached Devices
I get
Menu: Configure Attached Devices
**No devices detected on Qwiic bus**
1) Configure Qwiic Settings
x) Exit
Thank you,
Joe
By PaulZC
#220965
Hi Joe,
I agree. Something strange is happening... The MS8607 should "just work" but I see that sometimes it is detected and sometimes isn't. Here's what I got on the first try with the default settings:
Logging to: dataLog00022.TXT
Finding the next available log file.
This could take a long time if the SD card contains many existing log files.
Logging to: serialLog00000.TXT
SD card online
Data logging online
IMU online
Autodetect complete
PHT-MS8607 online at address 0x40
rtcDate,rtcTime,aX,aY,aZ,gX,gY,gZ,mX,mY,mZ,imu_degC,humidity_%,hPa,degC,output_Hz,
01/01/2000,00:04:41.87,-142.58,-16.60,-1003.42,-0.38,-0.08,2.21,-20.70,23.55,-89.70,24.20,50.27,999.62,19.35,17.24,
01/01/2000,00:04:41.97,-154.30,-25.39,-1004.39,1.67,-1.37,1.58,-21.00,22.80,-88.95,24.34,50.27,999.67,19.45,12.35,
And then I tried again with the debug messages turned on (you can enable these through a hidden menu - type "d" from the main menu and the debug menu will appear):
Logging to: dataLog00024.TXT
SD card online
Data logging online
IMU online
detectQwiicDevices started
detectQwiicDevices: something detected at address 0x76
Autodetect complete
beginQwiicDevices: No devices detected
printOnlineDevice: No devices detected
rtcDate,rtcTime,aX,aY,aZ,gX,gY,gZ,mX,mY,mZ,imu_degC,output_Hz,
01/01/2000,00:09:28.75,-146.48,-12.21,-993.16,1.79,0.66,-0.34,-25.20,25.20,-90.45,24.10,333.33,
01/01/2000,00:09:28.85,-129.39,-10.74,-987.79,1.22,-1.59,-0.34,-24.15,25.20,-91.20,23.86,19.42,
The MS8607 is unique in that it appears as two I2C devices, one with address 0x40 and one with address 0x76. 0x76 is in the mux address range, so I wonder if it could be something to do with that? I shall need to investigate this... I've opened an Issue here:
https://github.com/sparkfun/OpenLog_Artemis/issues/54
Thanks for letting me know.
Very best wishes,
Paul
By JD71
#221691
PaulZC wrote: Tue Dec 01, 2020 10:38 am Hi Joe,
Firmware version 1.8 has just gone live. You can find update instructions here:
https://github.com/sparkfun/OpenLog_Art ... UPGRADE.md
And the new binary file is here:
https://github.com/sparkfun/OpenLog_Art ... r/Binaries
Please let me know if this fixes the issue. I've tested it here - but you never know!
All the best,
Paul
Paul,
I loaded version 1.8 but the MS8607 still does not work as a Qwiic. It does work as an I2C sensor. I connected a SPX-16770/Qwiic PT100 to test the OpenLog Artemis and it works.
Thank you,
Joe
By PaulZC
#221694
Hi Joe,
Can you please enable the debug messages - type "d" at the main menu to see the hidden debug menu.
Then please post all of the debug messages here so I can take a look. They should tell us what is going wrong.
Thank you,
Paul
By JD71
#222037
Paulo,
Finally, I had a chance to test the MS8607
Summary:
Communication between OpenLog Artemis and MS8607 via Qwiic only works if another Qwiic device is attached to the MS8607. Conducted 4 trials with two OLA (I have 2 called OLA1 and OLA2), 1 MS8607 and 1 SPX-16770 with PT100 temperature sensor.
OpenLog Artemis
1. Trial #1 Using Tera Term
OLA1 connected with Qwiic to MS8607
Artemis OpenLog v1.8
Logging to: dataLog00164.TXT
SD card online
Data logging online
IMU online
01/01/2000,00:04:16.26,-548.83,-165.53,-833.98,-2.34,0.05,-3.68,-18.45,-66.60,-19.65,25.25,250.00,
01/01/2000,00:04:16.36,-549.32,-157.71,-839.36,-0.88,-0.43,-2.15,-16.80,-66.00,-21.60,25.44,19.42,
2. Trial #2 Using Tera Term
OLA1 connected with Qwiic to MS8607 connected to SPX-16770 (Qwiic PT100 ADS122C04) with PT100
Logging to: dataLog00165.TXT
SD card online
Data logging online
IMU online
detectQwiicDevices: MS8607/MS5637 found at address 0x76. Ignoring it for now...
detectQwiicDevices: something detected at address 0x40
detectQwiicDevices: added PHT-MS8607 at address 0x40
detectQwiicDevices: something detected at address 0x45
detectQwiicDevices: added ADC-ADS122C04 at address 0x45
Autodetect complete
beginQwiicDevices: attempting to begin deviceType PHT-MS8607 at address 0x40 using mux address 0x00 and port number 0
beginQwiicDevices: device is online
beginQwiicDevices: attempting to begin deviceType ADC-ADS122C04 at address 0x45 using mux address 0x00 and port number 0
ADC-ADS122C04 online at address 0x45
Device count: 2
rtcDate,rtcTime,aX,aY,aZ,gX,gY,gZ,mX,mY,mZ,imu_degC,humidity_%,hPa,degC,degC,degC,output_Hz,
01/01/2000,00:25:32.86,-12.21,-144.04,-997.56,-1.40,0.89,-0.16,-24.15,-49.20,-
3. Trial #3 Using Tera Term
OLA2 connected with Qwiic to MS8607
Logging to: dataLog00167.TXT
SD card online
Data logging online
IMU online
01/01/2000,00:00:17.47,556.64,-63.48,-833.01,-1.80,-4.37,3.33,-61.95,-28.20,-73.20,25.78,333.33,
4. Trial #4 Using Tera Term
OLA2 connected with Qwiic to MS8607 connected to SPX-16770 (Qwiic PT100 ADS122C04) with PT100
Logging to: dataLog00168.TXT
SD card online
Data logging online
IMU online
Autodetect complete
Device count: 2
01/01/2000,00:03:27.55,463.38,-27.83,-890.14,2.25,-0.64,3.44,-53.85,-25.50,-87.00,26.83,33.23,985.75,23.36,22.858,22.094,5.68,
01/01/2000,00:03:27.78,469.73,-25.88,-899.41,1.80,0.85,2.05,-51.45,-23.40,-85.35,26.93,33.23,985.79,23.42,22.783,22.125,5.00,
01/01/2000,00:03:27.96,457.03,-32.71,-901.37,0.00,-0.17,2.01,-52.50,-25.65,-87.15,26.83,33.23,985.83,23.47,22.782,22.125,5.13,
01/01/2000,00:03:28.14,449.71,-43.95,-892.09,-1.08,-2.25,-0.62,-51.00,-22.20,-86.70,26.83,33.23,985.82,23.49,22.779,22.156,5.25,
01/01/2000,00:03:28.36,457.03,-27.34,-902.34,-2.68,0.57,-0.76,-51.60,-24.00,-87.00,26.93,33.23,985.80,23.48,22.784,22.156,5.11,
By PaulZC
#222063
Hi Joe,
Many thanks for the diagnostics - that helps a lot.
I'll look at this as soon as I can. (There is another issue that needs solving too - misbehavior when connecting two MS8607s.)
Best wishes,
Paul
 Topic permissions
