By Baldurk
#212767
Hi there,
I just bought myself the RedBoard Artemis along with various Qwiic modules for a project but when I was going to start changing I2C addresses for two Qwiic Buttons, the board had trouble reading the I2C bus.
Using the I2C scanner sketch the board reads a device on every address.
The problem seems to be the ReadBoard since I swapped it out for an Arduino Due and that worked as expected.
This is similar to reading an I2C bus without pull-up resistors but since this is the Qwiic system, that can't be the problem can it?
Can someone help me with this?
#213281
Hi Baldurk,
Out of curiousity, what SVL Baud Rate did you use to program the RedBoard Artemis?
I experienced this exact same problem yesterday when trying to connect I2C devices to my Artemis Nano. I ran the same I2C Scanner sketch and no I2C devices were detected. I then realized I had unknowingly left the SVL Baud Rate at the default of 921600. As soon as I changed this to 115200 and re-uploaded the sketch, my I2C devices were detected.
Hopefully this helps!
Cheers,
Adam
 Topic permissions
