Update: installed the driver from here:
https://github.com/adrianmihalko/ch340g ... l_V1.3.zip
I now have duplicate serial ports (/dev/cu.usbserial-1420 and /dev/cu.wchusbserial1420), but uploading works. It seems like maybe the built-in Catalina driver doesn't work with this board yet.
The output with the built-in driver is below:
Writing to file /var/folders/dr/l7mlbx6s1wb061grlnkgpykr0000gn/T/arduino_build_910253/sketch_nov28a.ino_Wired_OTA_blob.bin
Image from 0x0 to 0x18640 will be loaded at 0x20000
Connecting over serial port /dev/cu.usbserial-1420...
Sending Hello.
No response for command 0x00000000
Failed to respond
Fail
Sending Hello.
Failed to respond
Fail
Sending Hello.
Failed to respond
Fail
Tries = 3
Upload failed
