What are we doing right with Artemis? What are we doing wrong? Let us know here!
By HarisUoE
#247346
On the data sheet DS-000189-ICM-20948-v1.3 for Artemis OLA the terms "Initial ZRO Tolerance", "Initial Tolerance" and "Initial Calibration Tolerance" are mentioned for gyro, accelerometer and mag sensor respectively
. Can you clarify if these are the tolerances before the run time calibration is applied or do they mean that the run time calibration takes these limits into consideration.
I am a bit confused about these.
 Topic permissions
