What are we doing right with Artemis? What are we doing wrong? Let us know here!
#209905
liquid.soulder wrote: Thu Oct 31, 2019 12:29 pm
FWIW my launch.json file looks like this:
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "type": "cortex-debug",
            "request": "launch",
            "name": "Cortex Debug",
            "cwd": "${workspaceRoot}",
            "executable": "${workspaceRoot}/BUILD/EDGE2/GCC_ARM/mbed-os-example-blinky-baremetal.elf",
            "serverpath": "C:/Program Files (x86)/SEGGER/JLink_V642/JLinkGDBServerCL.exe",
            "servertype": "jlink",
            "device": "AMA3B1KK-KBR",
            "interface": "swd",
            "serialNumber": "", //if you have more than one J-Link probe add the serial number here
            // "jlinkscript":"${workspaceRoot}/BSP/SEGGER/K66FN2M0_emPower/Setup/Kinetis_K66_Target.js",
            "runToMain": true,
            "svdFile": "C:/Users/user/AmbiqMicro.Apollo_DFP.1.1.0/SVD/apollo3.svd",
You can get the Device Family Pack for the Apollo3 (which contains the SVD file) here:
https://www.keil.com/dd2/pack/#third-pa ... oad-dialog
Can you give more details on getting the SVD file? I downloaded the link you provided, but it is a ".pack" file. I'm not familiar with that format and how to use it. Thanks.
#209908
There is an easier way: the Ambiq Suite release itself contains the Apollo3 SVD file. The file is located inside the Ambiq Suite hierarchy here: <...>\AmbiqSuite-Rel2.2.0\pack\SVD\apollo3.svd
#209915
Sure thing. It was actually much easier. If you go into the VS Code extensions manager and search for "cortex", you should see a plugin called "Cortex-Debug" by marus25. Install it. Then, configure your launch.json file as noted above with your personal customizations. You'll need the ELF file compiled/linked (all objects, too) with the "-g" flag. Start the debugger from VS Code. The server should start and connect to your target. You can set "runToMain" true/false in the JSON file. I did have a few hiccups because I hadn't set paths correctly. Once I got that corrected and added the SVD path you provided (thanks again), all seems to be working. I've got source, vars, watch, call stack, BP's, Cortex Periphs/Regs. I'm stepping, running, etc. I've also got my printf's going to my terminal app. It's very, very handy. I made a lot of progress today. The great thing is that I don't have to worry about the cost of SES or another product. And, I can use this for any potential commercial stuff. Let me know how it goes. I don't think I left out anything major.
 Topic permissions
