- Mon Dec 12, 2022 10:59 am
#237630
I got a new a OLA board a couple weeks ago and initially had success connecting it to a couple qwiic devices, configuring output, and even getting output over a RN-42 bluetooth module. Once I started putting in SD cards, it started getting wonky, and now doesn't work at all. With the SD card in, I get no output over the USB at all; it does appear to write files to SD though. Without an SD card, I get as far as below, but then it just hangs as far as the terminal goes.
I have tried reloading firmware (OpenLog_Artemis-V10-v24.bin), and it does load successfully, but get the same output. I have some feeling it has to do with config file settings, but not sure. Where is the config file if there is no SD? Is there a way to force wiping the config file? Kinda stuck here...
Without SD card:
SD init failed (second attempt). Is card present? Formatted?
Please ensure the SD card is formatted correctly using https://www.sdcard.org/downloads/formatter/
Config file read failed: SD offline
Without SD card:
