- Mon Mar 29, 2021 10:02 am
#224477
Hello
I just started working with the SPARKFUN Redboard ARTEMIS (15444) together with the Arduino IDE. I installed everything as indicated in SPARKFUN tutorial https://learn.sparkfun.com/tutorials/ar ... th-arduino. Everything goes perfect, even de the available led blink example (in the tutorial considered as “a good benchmark to make sure you've got your core installed correctly and you can upload code to your module”) runs from the first time! But after compiling this extremely short example, I got this information: almost 116kB (11%) programming space used and almost 28kB (7%) ram space for global variables! Can anyone explain???
