By benedic2
#216844
Hello, I am fairly new to using redboards. I have a redboard Artemis Nano. the site says there are 4 i2c buses on the board (including the QUIC connector). I was wondering if anyone knows of a guide, example, video, tutorial etc... on how to use more than one i2c bus? It seems obvious, but I have not found too much help.
BTW, the reason is I have two sensors with the same i2c address, so to use them both I would like to use the QUIC connector and a second i2c bus.
THANKS!
By liquid.soulder
#216857
Declare a new wire port using the IOM instance that you want like this:
TwoWire myWire(N);
Choose N depending on which pins you want to use (there are 3 options that aren't on the qwiic connector) for example pins 9 and 10 on the Nano are connected to IOM# N=4
https://cdn.sparkfun.com/assets/5/5/1/6 ... s-Nano.pdf
Then you use "myWire" just like you would the normal "Wire"
 Topic permissions
