EM401 unhappy
Locked
carterson2
Contact:
EM401 unhappy
Post by carterson2 » Mon Nov 27, 2006 8:44 am
My Em401 seemed to quit sending.
Pin6(vcc) has 5v,
Pin5(tx) has nothing (just sits at +3v, dead)
Pin4(rx) on scope shows good RS232 signal coming in when I type using teraterm.
Pin3(/reset) I connected this to gnd momentarily to try resetting it, but didnt help.
Pin2(gnd) hasn't changed
Pin1(gnd) hasn't changed.
The EM401 is connected to a Eval-EM406-RS232 which I wired to work. It has worked great for 2 months in my car. Then it just stopped sending...
No matter what I do, I never see anything come out. Even connecting pin3 to gnd, didnt cause any garbage to show up on teraterm (hyperterm). At 4800, I sent it $PSRF100,1,9600,8,1,0*0C to change speed to 9600, but that didnt do anything.
Q: Can I perhaps unhook the battery somehow and get it to hard-reset somehow???
Thanks for any leads,
jim pruett
ohararp
Contact:
Post by ohararp » Tue Nov 28, 2006 8:23 am
Jim,
Isounds like the MAX23X rs232 chip on your dev board may have died. I had a similar inexplicable problem.
Ryan
Regards Ryan :-)
$25 SMT Kapton Stencils - http://www.ohararp.com/
US Distributor of PDS - http://www.ohararp.com/compilers.html
carterson2
Contact:
Post by carterson2 » Tue Nov 28, 2006 8:33 am
I called usglobalsat and they think their chipset died. They also say the warrantee is thru sparkfun which is better than if I had for example bought it off ebay in which case they said I would be SOL.
BTW, I connected pin 5,6 together to do a loopback which worked.
That eliminated the max chip.
Have fun.
jim
carterson2
Contact:
Post by carterson2 » Tue Nov 28, 2006 8:34 am
oops, I meant pins4,5.
Locked
Return to “GPS”
