#202018
Hey guys,
So recently I dug up a Venus638 to play with and decided to write a small library header and release it into the wild, only trouble is the datasheet is very hardware orientated, there is no reference manual, and most of the info is in the app notes. Which is fine for such a small and relatively limited device.
Problem is that on the product page, there is only the datasheet. I had to google for the application notes, upon which I come across these two:
https://cdn.sparkfun.com/datasheets/Sen ... ogging.pdf
https://cdn.sparkfun.com/datasheets/Sen ... 1.4.19.pdf
Yet when I go to the parent folders it tells me access is denied. I'm just curious to know if there are any other application notes available, as there certainly aren't any through the vendor.
Further, it makes me curious if there is documentation that sparkfun is withholding for any reason, or if I need special access to gain that information.
Thanks
MM25
