#181937
Hi all,
I'm using a DIY datalogger/dataacq setup for my race car. It uses an active external GPS antenna from Adafruit: http://www.adafruit.com/products/960
For cleanliness and convenience, I'd prefer to mount the antenna inside of my car. The sunroof has been deleted and replaced with a fiberglass panel. Would it be possible to mount the GPS antenna upside down under the fiberglass panel? Or I suppose since I'd be using double sided tape, I could mount it right side up under the panel. But does it need to be mounted on a metal surface? I've read some things saying that some types of antennas require a metal ground plane below.
Thanks a lot,
Dan
