- Fri Dec 21, 2012 12:25 am
#153397
Hope someone else has some experience with the GPS GP-635 module.
https://www.sparkfun.com/products/11571
I have been successful in connecting the the GSP Module - GP635-T via serial connection. It produces output readings every 1 second as expected at 9600 baud 8-N-1. The datasheet mentions that the baud rate can be changed, but I have not been able to figure out the syntax. The datasheet hints that it can be done at the factory depending on Minimum Order Quantity, but I would like to change it myself.
Also, I tried to place the module in low power mode by grounding pin 6 (PWR_CTRL), but the module keeps sending in messages. Shouldn't it stop sending if this pin is LOW? I need to be able to stop it to conserve battery and this was one of the reasons I bought it, but no luck.
Any suggestions on how to change the baud rate on this module and/or place the modle in low power mode? I looked in the vendor site and Googled around, but no luck.
