- Fri May 13, 2011 8:11 am
#127117
Hi again!
I am now working on a charging circuit for my GM862 and I was wondering if I have the right Switching Regulator. I have an DE-SW050 from Dimension Engineering (http://www.dimensionengineering.com/DE-SW050.htm) which can apparently output up to 1A. After checking the GM862 Battery Application note, I saw that the Max current was 1A, but the recommended current was 400mA. The Regulator will be connected to a 12v line in a car.
Does anyone know if I will need protection for the regulator from the cars power supply? And will I need any additional components for the charging circuit?
Thanks,
James
Thanks,
James
