- Mon Oct 25, 2010 8:06 am
#112083
Hello there,
I have a few questions regarding the following products:
http://www.sparkfun.com/commerce/produc ... ts_id=8418 and http://www.sparkfun.com/commerce/produc ... ts_id=8825
So one is the receiver and the other is an antenna. Here's my question. I am trying to play a little treasure hunt game. Here's what I have in mind:
Attach it to a card/ coin, etc
It's destination will be domestic (within the US)
Don't need any 1Hz update rate. Instead this update once in 2 weeks or once a month if needed (hopefully minimizing battery requirements)
Speaking of battery, what is the source for something like this?
This tracker will be hidden in small items and therefore needs to be small and inconspicuous. (Strategy involves several pieces hidden around and one of those will be the right one with the GPS but the person trying to find it should not be able to easily tell its a GPS tracker)
Use GPS visualizer or other software to track with periodic updates.
With the two units mentioned above (20 Channel Micro-miniature MN5010HS GPS Receiver and Antenna GPS Chip-Scale) will I be able to carry out what I mentioned above in the idea? Do I need other components?
Thanks for your time and patience in advance.
