- Mon Oct 04, 2010 10:06 am
#110751
I found this post entitled
It does work, provided you send the commands to the SiRF chip at the baud rate it was programmed with previously ... try different baud rates if it doesn't work for you.
By the way, you can find the SiRF Binary Protocol manual at http://www.usglobalsat.com/downloads/Si ... otocol.pdf
Putting your EM-406 GPS back in to NMEA mode without waitingat http://diydrones.com/profiles/blogs/put ... e=activity, it may prove useful to someone.
