- Mon Oct 13, 2008 3:28 pm
#57021
The setup would consist of a surface mount GPS antenna (from sparkfun), an in-line LNA, and GPS receiver.
I would like the surface mount GPS antenna and LNA to be an "active antenna", as the GPS receiver injects 3.3VDC on the coax.
The reason why I can't just power up the LNA with the traditional power supply is because the GPS has great power management using push-to-fix, and I do not want to run the amplifier when it wont be used.
I have had a very difficult time trying to track down an amplifier (and more importantly) the app notes related to the amplifier to operate it off DC power supplied by coax.
Does anyone know of any components that would be of use for the LNA? Im certain there has to be some low cost, cheapo LNA IC that these gps antennas are using...
