- Mon Oct 16, 2023 5:37 pm
#244584
Hello, I found some older topics on this issue, but no real resolution for Windows. I am running windows 11 Home 22h2. I am using the arduino IDE 2.2.1 and have a sparkfun artemis redboard. I have installed the Sparkfun Apollo3 board manager 1.2.1 core.
I am simply trying to get Blink to run. When I compile and upload the following is displayed:
"Sketch uses 8644 bytes (0%) of program storage space. Maximum is 960000 bytes.
Global variables use 33820 bytes of dynamic memory.
Artemis SVL Bootloader
COM1 is currently open. Please close any other terminal programs that may be using COM1 and try again."
I have tried various USb ports, but no joy. Also I should note that the PC does not beep when I connected the board to the computer via USB A to USB C. This is different behavior than when I hook up an arduino board
Thank you!!
Thank you!!
