- Sun Dec 12, 2021 8:49 pm
#230098
I am working with the Artemis Dev Kit and writing software in Arduino. I have a simple test that maintains a count in EEPROM and the value is preserved through a reset or power cycle but when I download an update to the firmware the EERPOM value is lost. I suspect that this has something to do with the EEPROM being simulated with flash and the flash being updated by the firmware update.
Is there any way to avoid having the EEPROM wiped by programming? Would I have the same issue if programming the Artemis via the serial interface (I think the Artemis Red Board uses serial) vs the Dev Kit's drag and drop method?
Thanks,
Phil
Thanks,
Phil
