- Fri Nov 01, 2019 6:21 am
#209179
I'm using an Artemis ATP with the uLCD-32PTU. I have a sketch that works fine with an Arduino Mega 2560: stable for weeks at a time. Since my project will be using several qwiic boards, I switched to the Artemis ATP with qwiic connectivity. The issue is that I am communicating with the uLCD on Serial3 of the Arduino Mega at a baud rate of 200000 and everything works fine, when I moved to the ATP I switched to Serial1 at a baud rate of 200000 and the uLCD only receives the first write to it before locking up. I tried faster and slower baud rates with no luck. In fact, the only time it works at all is at 200000, but again it only response to the first command.
