Moderator: robacarp
By Brandon121233
#31571
Hey guys,
I just finished up my first PCB made in Eagle, for a robot. However when I submitted it, it failed the DRC bot. here is the Email:
Thank you for submitting your design to BatchPCB!
Unfortunatly, your design "Walbot PCB" violates our design rules of 8mil traces with 8 mil trace spacing. Your design has now been removed from our servers.
Please double check your layout. Images of the Top and Bottom copper layers are attached. Also attached are logs output by the DRC bot. Traces are colored Purple if they violate the trace spacing requirements, and Orange if they violate the minimum trace width requirenments.
Fear not, you can resubmit your design as many times as you want.
Thanks again for using BatchPCB.
Please don't reply to this email, the BatchBot will eat it.
unmatched 274X paramblock OFA0B0 - len 6
Macro Name = OC8
Macro Consuming 5,1,8,0,0,1.08239X$1,22.5 [2]
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Looking up macro OC8 [0x54f140]
Beginning GCODE run
Ending GCODE run
Created 327 polygons
Found 0 errors
Partitioning....
Grouping...
Distance testing
MergeCount: 250
tests: 15897
Board boundaries: Rect: [0.101800,0.101800] -> [3.101800,2.301800], w: 3.000000, h: 2.200000
Found 77 groups
lengthdb size 0
DRC Error - trace to narrow
Macro Name = OC8
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Beginning GCODE run
Ending GCODE run
Created 430 polygons
Found 0 errors
Partitioning....
Grouping...
Distance testing
MergeCount: 324
tests: 25436
Board boundaries: Rect: [0.161800,0.161800] -> [3.041800,2.263800], w: 2.880000, h: 2.102000
Found 106 groups
lengthdb size 0
any help would be appreciated
By Tomasu
#31572
I can only say two things.
1. It told you why it failed, and told you where it saw the errors via the images. Should be easy to fix.
2. You can't link directly to images off gmail like that. Its part of your account. Try uploading them somewhere else.
By Brandon121233
#31579
sorry, here they are. But it says that errors will be in purple or orange, and I don't see any purple or orange in these images.
By Tomasu
#31580
That is a little odd. Someone with more experience will have to follow up :o
By busonerd
#31581
Look at the borders - you have a 0 mil line encircling your board as the board outline. Bump that up to 8 mil and you'll be good.
Cheers,
--David Carne
By Brandon121233
#31583
Thanks busonerd it worked, sorry for troubling you guys with this, its my first time doing this so I was a little lost. But it worked!
By denisbest
#31769
I have the same problem to pass the DRC bot. My design seems to be compliant, but not. Please check what is wrong with my "LED Matrix" design.
