Moderator: robacarp
By MJ
#7800
I'm getting the following error when I try out my board.. To my knowledge, I'm not using a drill of that size anywhere in the board. Any ideas why this drill would be showing up in the file, and how (if it's not being used) to get rid of it?
I've attached my DRD file from Eagle v4.15 for reference.
Thanks,
Jeff
Drill Too Small in line: T01C0.0197
M48
M72
T01C0.0197
T02C0.0236
T03C0.0320
T04C0.0360
T05C0.0400
T06C0.0440
T07C0.0900
T01
X4152Y3653
X4644Y3653
X5136Y3653
X5628Y3653
X6120Y3653
X6612Y3653
T02
X6352Y5861
X5382Y6661
X4832Y6771
X4082Y7131
X2782Y6561
X4132Y10971
X4732Y11471
X5332Y12971
X6332Y11271
X5942Y9911
X6332Y9071
X7082Y9961
X7172Y8531
X8402Y10311
X7432Y12971
X6832Y17271
X4032Y15571
X4032Y14971
X8082Y6261
X10532Y3071
X9832Y2371
T03
X10542Y2571
X10542Y4471
T04
X5874Y5061
X5874Y5841
X4890Y5841
X4890Y5061
T05
X9692Y5981
X9692Y8541
X9692Y9781
X9692Y12341
X11472Y12341
X11472Y9781
X11472Y8541
X11472Y5981
X5982Y19161
X4982Y19161
X3982Y19161
X2982Y19161
T06
X4232Y17281
X11232Y19281
X11232Y15281
T07
X3012Y3991
X7752Y3991
M30
[/b]
By Philba
#7803
according to your drill file, you are using that drill 6 times. What happens when you run eagle's drc? Both tool 1 and 2 should get flagged if you are using the default drill size min (drc/sizes tab) of 24 mil.
It's probably coming from a 6 pin, 50 mil pitch component at 0.4152,0.3653 - load the component layer into viewmate and then import the drill file. You should see it.
By MJ
#7811
Wow; thanks for the insight.. I will check out the board again with what you told me and see what I find.
Thanks again,
Jeff
By MJ
#7854
Yep; you're exactly right. I didn't know how to read those things, but now I do! I fixed it and am about to order it in a bit.. Thanks much.
Jeff
