PCB CNC machine
Moderators: phalanx, robacarp
rf333
Post by rf333 » Mon Apr 13, 2009 5:18 am
NleahciM wrote:... The board you posted a photo of has a number of vias on the thermal slut of a QFN. How do you plan on soldering those?
Additionally, what's the cone shaped piece of copper on the PCB for? I must admit my ignorance in the RF field.
Yea, I ran this board just to test the machine. It is a demo from Atmel. http://www.atmel.com/dyn/products/produ ... rt_id=3413
The existence of many holes (more accurately 356 and 300 of them 12 mils) and 4 to 8 mils traces attract me to se how the machine will perform. And it is time saver to run ready made projects :).
In our future projects we will look for designs that are easier to prototype (in many cases this is helpful in mass production).
The cone shaped feature is an antenna.
leon_heller
Post by leon_heller » Mon Apr 13, 2009 5:24 am
I can't see the point of CNC for making PCBs. I can make a PCB in about 20 minutes (plus drilling) at home using the photo etch process. 8/8 mil design rules aren't a problem although I usually use 10/10. I can get down to 5 mil tracks if necessary.
The equipment cost me under $100.
Leon
Leon Heller
G1HSM
funnynypd
Contact:
Post by funnynypd » Mon Apr 13, 2009 5:46 am
if you are playing only with single side, it is fine for both.
However, if you like high quality two layer or multiple layer PCB, and you can wait, a PCB house may turn out good quality boards at a relatively low cost.
funnynypd
Contact:
Post by funnynypd » Mon Apr 13, 2009 5:48 am
It is amazing my HP printer only use single layer PCB, and there are lots of high-tech jumpers which doesn't seems cheap.
Don't understand why they only use one layer PCB.
leon_heller
Post by leon_heller » Mon Apr 13, 2009 6:31 am
It obviously worked out cheaper for mass-production.
Leon
Leon Heller
G1HSM
Philba
Post by Philba » Mon Apr 13, 2009 8:43 am
Double sided is pretty easy to make via any in-home wet chemistry. Yes, it takes a little experimenting to get the process right but anything has a learning curve.
funnynypd
Contact:
Post by funnynypd » Mon Apr 13, 2009 8:58 am
Is there a standard through-hole plating kit available?
rf333
Post by rf333 » Wed Apr 15, 2009 4:45 am
Philba
Post by Philba » Wed Apr 15, 2009 7:46 am
I don't waste my time with plating holes. It's not really worth the effort. You can use wire to connect the two sides of a via. If you think about the lack of PTH during your design you can compensate. To pass a signal from one side to the other either use a via or a pin that is exposed for soldering on both sides. It does force you to design your board a little differently but in the end it's not much extra effort at all.
alnx
Post by alnx » Fri Apr 17, 2009 2:32 pm
Dear rf333
i'm asking about the Professional vacuum system what is this for ?
and is the machine noisy i mean i can put it in the office
thanks in advance
rf333
Post by rf333 » Sat Apr 18, 2009 8:19 am
alnx wrote:Dear rf333
thanks in advance
Actually the noise comes from the vacuum, that collect debris from machining. The professional vacuum is very quiet and according to Accurate has a submicron filter. I am running it in my office. The noise is comparable to a dot matrix printer :D
funnynypd
Contact:
Post by funnynypd » Sat Apr 18, 2009 9:16 am
wow, that's an excellent job on noise damping.
marianmp
Post by marianmp » Tue Jun 23, 2009 8:31 am
My vacuum is outside the office in a small storage room, so I don't have any noise or dust problems :)
wormsmith
Second Hand PCB CNC
Post by wormsmith » Wed Jul 15, 2009 1:31 pm
I almost have the boss talked into a PCB CNC/milling machine at work. We really need it! Is there any good place to find a listing of second hand machines from LPKF, Accurate CNC or T-tech? Trying to keep cost down but also looking to get auto tool changing, vacuum table, enclosed, 8 mil and camera if possible. Two layers will need to be done on the machine. Please send any recommendations, previous experiences etc. Thanks for any help.
leon_heller
Post by leon_heller » Wed Jul 15, 2009 1:47 pm
LPKF themselves often have used machines for sale. They offered me one when I was chatting to them at the recent Electronics Week show in London.
Leon
Leon Heller
G1HSM
Locked
