- Mon Aug 20, 2007 1:54 pm
#33990
I have a MLX90609 from sparkfun (+-75 degrees/sec on breakout board) which appears to be malfunctioning, the ADC output is hovering around 920 to 940. The gyro was working nicely on arrival, and I managed to obtain good heading data. However, during a cooldown test to -21c (peltier cooler) the output went off to a 920 to 940 ADC output, and was unresponsive. This disappeared after the power was disconnected and the reconnected around 15 seconds later.
The problem has not reappeared, and is continuous. Upon further investigation I find that the ERR pin is high, Selftest pin is high, current into VCC is 16.2ma, and the analogue rate output is 2.30V. It was suggested to me that condensation formed during the cooldown test, but the gyro was securely wrapped in insulating tape. It also seems highly unlikely that the gyro could have been fried, antistatic precautions were taken at all times. I have tried a variety of power supplies with no luck.
Can anyone suggest anything? What is sparkfuns return policy? I have the data recorded during the cooldown test if that helps "prove my case". It would be extremely dissapointing if the gyro is broken, as it looked very encouraging before the problem appeared, keeping a heading to +-10 degrees over several minutes.
Laurence
Laurence
