By CaseyD-SFE
#191364
Hello!
I wanted to let you know that we've seen your post and someone from our Tech Support team will be responding back to you soon. :)
Thanks!
-Casey
By SFE-TS-Bobby
#191365
Sorry about the confusion. In order to be consistent with the rest of the tutorial, I have modified the tutorial’s code in the section “…to Processing” [ https://learn.sparkfun.com/tutorials/co ... processing ] to include void setup(){}
I changed this part of the tutorial:
For our `setup()` method in Processing, we're going to find the serial port our Arduino is connected to and set up our Serial object to listen to that port.
    // I know that the first port in the serial list on my mac
    // is Serial.list()[0].
    // On Windows machines, this generally opens COM1.
    // Open whatever port is the one you're using.
    String portName = Serial.list()[0]; //change the 0 to a 1 or 2 etc. to match your port
    myPort = new Serial(this, portName, 9600);
to:
