Control leds with lilypad mp3
Moderators: phalanx, CS Paul
tigearis
Post by tigearis » Sat Mar 21, 2015 9:55 pm
I am new to using arduino and am looking for some help. i have a lilypad mp3 and want to be able to the following things:
Press on button to start playing the first track and continue looping this track until the button is pressed again.
Once the button is pressed the second time, play the 2nd track and continue looping
With each button press loop the next track.
Another button to stop any track and reset and go back to the first track.
As soon as the power has been turned on i want to fade leds in and out but these leds will require a 9v power supply.
Any assistance in this would be greatly appreciated.
Cheers
Nathan
CS Paul
Re: Control leds with lilypad mp3
Post by CS Paul » Wed Mar 25, 2015 11:17 am
You'll probably have better luck over on the more technical side of the forums. The folks who can best help you are less likely to see your post over here.
