tutorial idea
Moderators: phalanx, CS Paul
debertin
tutorial idea
Post by debertin » Thu Feb 24, 2011 5:24 pm
I learned a lot from the "How to use a multimeter" tutorial. I would love to see something on the same level called "How to use an Oscilloscope". 'Scopes are more or less a mystery to me, and I suspect a lot of beginners are in the same boat.
Thoughts?
Thanks --
Dan D
fll-freak
Contact:
Re: tutorial idea
Post by fll-freak » Fri Feb 25, 2011 6:49 am
Do you know enough to even provide a list of topics you would want covered?
1) How to buy
2) Time base set up
3) Vertical setup
4) Trigger setup
5) Math functions
6) What a scope is good at
7) What a scope can't help with
In the mean time there are some good websites. Including my local LeCroy reps page at http://www.wd1v.net/ and his scope FAQ at http://www.wd1v.net/scopefaq/comments.php
nibbler
Re: tutorial idea
Post by nibbler » Fri Feb 25, 2011 10:14 am
Take a look at Tektronix's tutorials page: http://www.tek.com/learning/oscilloscope-tutorial/
The scope primer is quite in depth, and the poster/pocket guide give you some quick references.
phalanx
Non-SFE Guru
Re: tutorial idea
Post by phalanx » Fri Feb 25, 2011 11:52 am
I moved this topic to the Sparkfun Site Questions/Suggestions subforum...
-Bill
debertin
Re: tutorial idea
Post by debertin » Sun Feb 27, 2011 2:13 pm
1) How to buy
2) Time base set up
3) Vertical setup
4) Trigger setup
5) Math functions
All of the above!
-Dan
fll-freak
Contact:
Re: tutorial idea
Post by fll-freak » Sun Feb 27, 2011 3:35 pm
Now is SFE had a wiki, we could start this tutorial in parallel and get some crowd sourcing going!
I will start with this:
1) How to buy ... Credit card is best
2) Time base set up... Fasdt enough to see your signal
3) Vertical setup... Adjust to fit your signal top to bottom for best accuracy
4) Trigger setup... That was the Lone Rider's horse!
5) Math functions... +- FFT. Thats about it.
6) What a scope is good at... Looking at signals
7) What a scope can't help with... Brushing your teeth.
Seriously, Anybody know a wiki where we could start this tutorial?
